Trunk brake lights?
Old Oct 16, 2015 | 02:37 AM
civicboy420's Avatar
Default Ignition turned on. right reverse light turns on solid
Like the title says the right reverse light stays on solid when I turn the key to the second position. 98 Civic EX coupe manual transmission. Thanks
Old Oct 16, 2015 | 06:42 AM
Former User's Avatar
Default re: Ignition turned on. right reverse light turns on solid
Mess with your wiring lately?
Front or rear or both?
Old Oct 16, 2015 | 08:27 AM
Sorry I was in such a hurry at work. It turned out to be my right side reverse light. Had to unplug it. Haven't messed with my wiring. All I did was switch my taillights two weeks ago.
Old Oct 16, 2015 | 08:32 AM
Default Re: Ignition turned on. right blinker turns on solid
Reverse light - still have the problem?
Edit your first post. I edited the thread title.
Old Oct 16, 2015 | 11:15 AM
Default Re: Ignition turned on. right reverse light turns on solid
Yes I still have the problem... oh what to do.
Old Oct 16, 2015 | 11:19 AM
You likely have two problems --> The reverse lights switch is stuck on and the left reverse light bulb is burned out.
Your first post doesn't not mention whether you have an auto or manual transmission.
Old Oct 22, 2015 | 07:34 AM
Default Trunk brake lights?
Hey I have bought a set of red/clear Jdm taillights and there is a hole in the trunk section of the lights for another set of brake lights. The problem is there is no harness. I was thinking about buying the plugs and wiring to the corner brakes. Problem with that is, well you know. How do I get my trunk brake lights wired up? Piggyback off the 3rd brake light? 98 Civic EX Coupe 5 spd. Thanks.
Old Oct 23, 2015 | 08:48 AM
Default Re: Trunk brake lights?
Bump
Old Oct 24, 2015 | 05:15 AM
Bump bump seriously no one knows? I seen pictures online of eks with the trunk lights. I need to know how to do this. Please anyone?
Old Oct 24, 2015 | 07:37 AM
tony_2018's Avatar
Fish Twig
There suppose to be a trunk harness, you're missing it.
Old Oct 24, 2015 | 12:17 PM
I went to the wrecking yard and found two 98 Honda Civics and neither of them had the trunk harness there has to be another way. Besides it looks completely stock nothing has been ripped out. I don't think there is a trunk harness. At least not one with the two plugs. Maybe it just for 99-00s.
Old Oct 24, 2015 | 02:43 PM
tony_2018's Avatar
Fish Twig
So are you saying you have no reverse lights at all?
Old Oct 24, 2015 | 03:12 PM
I have reverse lights, just not the plugs for the trunk tail lights. I guess I can buy two plugs and run some wire and splice into the corner lights.
Old Oct 24, 2015 | 03:44 PM
I did have a burned out bulb and I'm going to replace the reverse light switch.
Old Oct 24, 2015 | 03:59 PM
Wdpfreak145's Avatar
Make sure you don't have the switch too tight in the tranny. Replaced mine thinking it was bad, overtightened, ran around all ******' day with the reverse lights on lol.
Old Oct 24, 2015 | 08:13 PM
Thanks for the heads up
Old Oct 27, 2015 | 08:58 AM
I picked up the plugs at the junkyard. Now I just need to know what gauge the brake light wire is.
Old Oct 27, 2015 | 01:40 PM
NotARaCist's Avatar
I never narc'd on nobody!
http://www.sunforceproducts.com/Supp...ctionTable.pdf
Old Oct 28, 2015 | 12:08 AM
Thank you very much that helps a lot
Old Oct 28, 2015 | 11:08 PM
Default Cluster short when I switch on running lights
I just replaced one of my glow gauge faces and put it back together and when I tried to put the cluster back into the car I accidentally cut the wire to the fuel gauge face. I unplugged the wire, turn my running lights on and all of a sudden my blinker lights are on, not flashing (speedometer moves up and down to the rhythm of the blinkers when blinkers are on. bright light is on, dimmed, my fuel gauge level is all the way up, and my rpm/speedometer are dancing around like crazy bouncing up and down. I have no idea what's causing it any help would be appreciated thanks guys.
Old Oct 29, 2015 | 01:01 AM
Default Re: Cluster short when I switch on running lights
Nevermind I fixed it. I just decided to rip the glow gauges out. No more short. I decided to go with a 00 EM1 cluster. Picking one up tomorrow. Sorry to waste a thread.
Old Oct 31, 2015 | 03:19 PM
I bought the plugs and wire and some wire loom and zip ties. I'm almost done wiring. I will post a pic when I'm done. I have a good feeling it's going to work. If it does I'm buying 4 leds tonight.
Old Oct 31, 2015 | 03:49 PM
I can't believe it worked! They look so good. How do I post a pic on here so I can show you guys?
Old Nov 1, 2015 | 12:50 AM
NotARaCist's Avatar
Upload the picture to imgur.com. It'll give you the BBCode, just copy and paste that here.
