headlight removal & install
91 Civic HB
I just recently bought a pair of projector headlights. I tried to remove the headlights but ran into some difficulty. I removed the top two bolts and the side bolt behind the corner lens, but the damn thing still won't come off. Is there another bolt or screw that I need to remove?
i would take the front bumper off and take the wole assembly out (dont forget the bolt on the side) and do all the other bolting/unbolting wile its off of the car then bolt the finished product in and off you go after the front bumper is on (just a side note)"why dont you make your car fast instead of wasteing $$ on headlights (unless yours broke)(but still!)
if your going to take the assembly out be carefull you need to take out the assembly includind the metal mounting bracket... today i tried to take out the glass light itself and broke the adjustment piece off the bottom of the head light
did any of that make sense oh well im tired
91akira
May 29, 2015 07:31 PM
SomedaySoon
Nov 8, 2006 10:51 PM
