Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
02 Civic LX Tranny died - swap or rebuild?
Old Oct 20, 2015 | 01:16 PM
Aerohitman's Avatar
Default 02 Civic LX Tranny died - swap or rebuild?
Okay, i basically i bought the car used with 190k miles (School ain't cheap) and everything was okay for a while then i noticed the car would take forever to accelerate between 30mph and 50mph. It kept going for a while and then one day i started hearing a grinding like noise whenever i accelerated. Yesterday my sister was driving it and it stopped accelerating and it was towed. I was able to drive back about 10-15min with it before it stopped accelerating again. I went to AAMCO to ask about a swap/rebuilt and they said they've seen a lot of bad valve covers on the transmissions an estimated somewhere around $400 for it. If it needed a rebuilt we're talking $1200 and up. They will only install AAMCO certified transmissions. Another ship i went to would put in a new tranny for about $300 and rebuild for again $1200 and up. If i took a chance on a used transmission should i get one from the same year or go for a 04 which i've read are better? The place i was looking into getting one sells them for $450 30 days warranty from Japan with under 55k miles if that helps. THanks to any replies in advance.
Old Oct 21, 2015 | 06:05 AM
NDNV's Avatar
Default Re: 02 Civic LX Tranny died - swap or rebuild?
Tough break man. Don't really know what to tell you but FWIW I used the opportunity of a failed transmission on an Odyssey van to reassess my vehicle needs and cost/benefit of keeping it. It would have cost $3-4K to rebuild that trans in my neck of the woods so I cut my losses on that van at 100K miles and 13 years of service and bought something smaller. I did get $2K for the van as a trade-in as a bonus.
The cheap and relatively risky option would be the used trans from Japan for $500.
The ideal would be the rebuild done properly with the upgrades (Sonnax), new TC, clutches etc. but would be $1,500 I imagine (mostly labor).
Old Nov 7, 2015 | 11:28 AM
TNight's Avatar
I have been going thru the same kinda of issue w/ my 01 EX w/ only 122k on it .I replaced the tranny w/ one from an 05 .it runs fine for the first few blocks 5 to 10 min then it starts getting slow off the line. When I first replaced it it gave all kinds of AT solenoid lockout codes but I think that was due to a bad electrical connection to the connector on the passenger side plug at the rear of the tranny. I replaced that took it for a drive and now I get 2 codes 1) ELD 2) complete auto trans failure Hmmm mind you this is from a tranny I just put in. the first tranny did nothing hot or cold. so if you find something please do share
MrOmar20
Jul 27, 2008 07:40 PM
Punker1234
May 30, 2005 08:20 AM
Civic4less
18
Sep 18, 2004 12:54 PM
bgoetz
Aug 26, 2004 06:06 PM
EnjoyTheRideDC2
Aug 3, 2004 08:51 AM
