Timing Situation
Old Oct 19, 2015 | 08:24 AM
X-wind's Avatar
Default Timing Situation
Hello,
Please help. 1988 CRX Si, all is stock SOHC 1.6
Got the motor to TDC on #1 properly in order to change timing belt. The camshaft sprocket markings though do not perfectly align with cylinder head! The motor was running good, albeit not quite perfect shes old & I got blowby on one cylinder. Starts are reliable but feel a smidge rough. Should I leave it and instal new belt as is or should I move the cam back maybe a tooth or two so it's perfectly lined up with the cylinder head. I'm not sure how critical the timing is here.
Had a hard time sleeping last night. Really appreciate any wisdom.
Not the engravements on the sprocket are not in line with the cyclinder head, as they ought to be.
Old Oct 19, 2015 | 03:18 PM
jlicrx's Avatar
Default Re: Timing Situation
on the Si D16A6, the marks at 3 o'clock and 9 o'clock do not line up with the top of the head like the D15 engine - the mark at 7 o'clock lines up with the pointer on the inside timing belt cover - look at the picture for the Si near the center of the page - also, make sure you are using the correct mark for TDC - it is the single mark off to the right of the three ignition timing marks
Old Oct 19, 2015 | 04:14 PM
X-wind's Avatar
Thank you so very much.
I just gave up on my 30 try or so to match up the 3 & 9 o'clock marks. Reading your post & walking back to the car I've got it pegged perfect. I can now start reassembly & working on the suspension parts. My Hanyne's repair manual has let me down.
Old Oct 19, 2015 | 06:44 PM
X-wind's Avatar
Could you confirm my crank pulley should be put on at 119ft-lbs? As well as the engine mount - Hayne's says "tighten the bolts securely"
Old Oct 20, 2015 | 02:03 AM
v4lu3s's Avatar
RTFM
you really should download a factory manual. I don't have links saved on this computer, but they are not hard to find, and they have the actual correct information for your car. I won't mess with Haynes, or Chiltons...unless I have no internet access and am working on a car that I have never downloaded the manual for, at one point I had them for at least a dozen different models of honda/acua.
Old Oct 20, 2015 | 03:07 PM
tamboo's Avatar
10 Year Member
pm'ed you a link to the manual at h**dah**kup. 8)
Old Oct 20, 2015 | 05:38 PM
X-wind's Avatar
Thanks! I got the car back together & it is back on the road for now. I'll use the manual your graciously linked me from here on out.
jiggacivic
Dec 24, 2011 06:48 PM
Boostedb20EH2
10
Mar 10, 2008 04:36 PM
SPOON_BeIgHtEeNsEe
Jul 26, 2007 01:13 PM
O RLY
Mar 26, 2005 08:36 PM
civicracer1993
Jan 12, 2003 08:53 PM
