2007 Accord V6 Haynes Manual
Old Oct 17, 2015 | 11:19 AM
ashtonallen's Avatar
Default 2007 Accord V6 Haynes Manual
I need to replace my ATF warmer on my 2007 accord v6. I don't have a shop manual and need a DIY for changing this part. Can anyone advise the correct steps? Next time you are in Wilmington, NC, beers are on me. Thanks, Ashton
Old Oct 18, 2015 | 03:02 AM
slowcivic2k's Avatar
Default Re: 2007 Accord V6 Haynes Manual
The warmer is on top of the transmission, and you'll need to remove parts from the vehicle to provide access to it. Here is a basic run down.
1: Locate the warmer on top of the transmission. It will be a brass-colored round cylinder. Remove the air intake and other parts as they interfere with your accessing it.
2: Drain the coolant to prevent contamination of the transmission. There are two rubber hoses that feed this device. After you drain the coolant, remove the lines.
3: Remove the 3 12mm bolts that secure the unit to the transmission. There are two o-ring seals underneath that seal the transmission fluid to the warmer.
4: Clean the area, and reverse the installation. Bleed the cooling system.
This is a straightforward repair. Why are you replacing this exactly? I've never had to replace one yet.
Old Oct 18, 2015 | 04:09 AM
Well, I found coolant in the transmission fluid. I think this is the source of the mixing. Do you know if that is accurate? Thank you for the help.
Old Oct 18, 2015 | 04:44 AM
I have heard that coolant getting into the transmission will cause the transmission to fail - at least in some cars. Would it be recommended to have the transmission rebuilt, even if the mixing was caught very early?
VTalwar214
Sep 17, 2013 04:22 PM
Atariwarrior
Jan 15, 2007 08:07 AM
EvenStar
Nov 4, 2006 10:34 PM
Eclipse
Aug 25, 2003 10:11 AM
