AZ DAP HATCH (5 LUG)(CTR)(SPOON)(TUCKED)(SHAVED)
1997 honda civic DX
clean title
DAP
AC + heat
NO power steering
Chassis mileage 160k
poor mans type r
gsr bottom end
ati super damper street (less then 200 miles)
81mm ctr pistons (7000 miles)
hasting rings (7000 miles)
baffled p72 oil pan (less then 200 miles)
b16 head
ti vlaves and retainers (7000 miles)
dual valve springs (7000 miles)
skunk2 pro 1 cams (7000 miles)
skunk2 cam gears
skunk 2 ultra street intake and 74mm pro series throttle body (both less then 200 miles)
royal purple oil less then 200 miles
honda mtf less then 200 miles
b16 tranny and its mint mint
stage 3 sprung clutch about 5k on it
whale ***** intake
down star complete trans kit clutch and tranny side
extremely healthy motor
valve cover freshly powder coated
aem fuel rail
rdx injectors
plm header
down star complete motor bolt kit
down star complete motor mount kit
Buddy club spec 2 header back
new less then 200 miles Hasport motor mounts
complete custom wireworx harness less then 200 miles
Brake line tuck and booster delete
Hush 22 clutch master spacer
Wilwood clutch master
Teflon coated clutch line
Tucked fuse box
Tucked battery
full energy suspension bushing kit less then 200 miles
power windows and door locks (i did the complete power door conversion, everything oem down to the locks no after market actuators) i added an actuator to the hatch though so they hatch can be unlocked with the remote
new moog inner and out tie rods less then 200 miles
interior:
nardi wood 360
works bell slim hub
splash by works bell quick release (google it if you dont know it $$)
Vti cluster
honda block of plate (discontinued one that reads honda) and carbon one that holds the wideband guage
ek4 clock block off
Recaro srd
Custom rails that sit really really low
custom back seat delete
ek4 black carpet
Oem black floor mats
Wood **** and f5 ball ****
ctr shift boot
integra arm rest
miracle x bar type 2
air bag delete
rear trunk light w/ LED (turns on when you open hatch vise versa)
jdm cup holders
exterior:
ctr headlights
ctr grill
ctr lip
ctr rear lip
spoon duckbill
real apr mirrors
thin side moldings
4dr handles
99-00 rear tail lights
98-00 rear hatch (has handle)
hood squirters, antenna, and rear wiper all shaved
shock towers raised
also has custom full sized aluminum radiator
Apr cap as well
suspension:
koni and GC 6k/5k with all 4 top hats
suspension technique drop forks
ctr/usdm itr 5 lug
f5 lcas less then 200 miles
f5 subframe brace less then 200 miles
beaks bar less then 200 miles
wheels:
Varrstoen v4s 16x8 1500 miles on them
195/40/16 s-drives 1500 miles on them one has about 200 cause discount ripped the bead on mine so they replaced it
security:
clifford 50.7x has all the bells and whistles among more
sure theres more i cant think of
asking 10k OBO as is could take some parts off for a better price if need be
clean title
DAP
AC + heat
NO power steering
poor mans type r
gsr bottom end
b16 head
skunk2 cam gears
whale ***** intake
aem fuel rail
rdx injectors
plm header
Tucked fuse box
Tucked battery
interior:
nardi wood 360
works bell slim hub
Vti cluster
ek4 clock block off
Recaro srd
ek4 black carpet
ctr shift boot
integra arm rest
air bag delete
jdm cup holders
exterior:
ctr headlights
ctr grill
ctr lip
ctr rear lip
spoon duckbill
real apr mirrors
thin side moldings
4dr handles
shock towers raised
Apr cap as well
suspension:
ctr/usdm itr 5 lug
wheels:
security:
