96 Honda Civic Instrutment Cluster lights not working
https://*******/YQce
Dashboard lights aren't working in the cluster but the turn signals, high beam, battery and gas icons things work.
Video link is attached to explain my problem.
somebody help please!
take her easy, there cocky face. you're the one who fucked up a simple radio install, not us. missing information, NOT found in your thumbnail sized video:
1- did you RE check the fuse after you replaced it? (odds are it blew again)
2- did you use a wire harness adapter or hack up the factory harness?
3- did you solder/shrink your wires or twist and tape?
all of these will help get you your answer. if you DID hack the harness, post pics of your connections.
Yes i checked the fuse after I installed a new one. it wasn't blown.
I bought a wire harness from Walmart and wired it together. could the radio be wired wrong??? used butt connectors to wire the radio.
Unplug the dimmer switch and short the red wire (not red/black wire) to the black wire in the dimmer switch connector. Do the cluster lights now work? If not, use a multimeter to test whether the red/black wire has battery voltage with lights turned on and whether the black wire has continuity to body ground.
19cIvIc94
Jun 3, 2007 05:37 PM
mrbsponge
Dec 31, 2003 03:31 PM
serboy00
Dec 20, 2003 06:49 PM
