OBD2a Unknown Connectors
Old Oct 14, 2015 | 10:53 AM
komet 163's Avatar
Default OBD2a Unknown Connectors
where they go these connectors? coming from one end of the wiring harness
the white connector on the left has 13 pins. and the other connector on the right has 10 pins
is from a D15B (D15Z7 3 STAGE VTEC OBD2A)
there will be some diagram for these connectors???
Old Oct 15, 2015 | 07:28 AM
komet 163's Avatar
Default Re: OBD2a Unknown Connectors
somebody ?????
Old Oct 15, 2015 | 10:34 AM
turbohatch96y7's Avatar
Blue is for distributor
White looks like junction connector
Post pics of the wires on the white connector
Old Oct 17, 2015 | 12:13 PM
komet 163's Avatar
blue is not for dizzy, because, it is connected to another connector equal pins to blue
Old Oct 18, 2015 | 07:38 AM
komet 163's Avatar
helppp
Old Oct 19, 2015 | 08:54 AM
Then Its the other end.
Look next to the driverside firewall shock tower the. Harness comes out next to the fender next to the clutch reservoir
Old Oct 19, 2015 | 05:50 PM
komet 163's Avatar
but what I need is to know which are the connectors. because it is a swap. and I need to match them with the internal harness which is OBD-0 ... and find the pinouts of these connectors
Old Mar 17, 2016 | 06:24 PM
Pitaxo's Avatar
Hello Friend. I like nesecito information that connector, you have the diagram? or you know that each color is? ( white connector ). Regards
iHOPEyouCHOKE
May 22, 2006 01:31 PM
crexer
17
Dec 12, 2005 08:26 PM
noob2k
Sep 5, 2004 07:36 PM
turbo sol
Jun 6, 2003 12:57 PM
ScottEK
Oct 24, 2002 06:15 AM
