b18c performer x
I not think so, if not all aftermarket IM have the same diameter runners.
itr manifold, b16, skunk, all, the entry port on the head are equal only to match the head port, but the internal diameters of runnes are different.
sorry for my Inglés.
I have a few different intake manifolds I could try and measure for you later today. I think I have a blox ITR style, oem ITR, Victor X, and a few LS manifolds.
If you have a general range of runner inlet size, you could probably get close to what your looking for. Then design in your taper to the port entry.
What country are you in?
ok thanks, it would be Helpful for me !!!
I am from peru
Your measured 44mm sounds about right in the range of the manifolds I just measured.
I was measuring about 1.8 inches in the OEM ITR and the Blox ITR copy and about 2 inches on the lightly ported victor X. These are rough measurements.
This is OEM ITR. Runner for cylinder 3.
Tape measure was not straight so I estimate 8 inches or so. The Blox is pretty much the same.
I'm pretty sure the performer X has longer runners.
Good information that you contribute, what I'm not sure is whether the plenum of the performer x is 2250ml, It is a measure that I took another thread, but I'm not sure...
99teggsr
Apr 25, 2005 08:35 PM
