D16A6 girdle bolts
Old Oct 12, 2015 | 08:12 AM
Freemananana's Avatar
Default D16A6 girdle bolts
I'm not sure if this is even a thing, but are any of the girdle bolts longer? I thought I had placed my bolts in order when I removed them, but one isn't threading all the way back into the block. The factory service manual didn't mention anything on the page I was looking at. I may have just been in the wrong area of the manual though.
Car is a '89 Si with a D16A6 bottom end.
Old Oct 12, 2015 | 11:42 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: D16A6 girdle bolts
I don't believe there's a difference. Have you tried swapping that one with another and seeing if they seat the same?
Old Oct 12, 2015 | 12:40 PM
I didn't. I came inside to research it last night and never went back out. I didn't think there was a difference. I'm just going to pull them and swap them around until it works out. Probably just me being stupid. I'll check the hole.
Old Oct 12, 2015 | 02:56 PM
jlicrx's Avatar
(8) bolts are 116mm long and (2) are 131mm long - the long ones are closest to the flywheel
Old Oct 12, 2015 | 03:20 PM
24TEN's Avatar
PHANTOM MENACE
I sit corrected
Old Oct 12, 2015 | 04:05 PM
I ended up finding this out this evening. I just pulled them until I found where the other long bolt was hiding and placed the one I had across from it.
I was just confused by them not being the same length. This is the only time I've been inside a D-series motor and I just don't want to screw something simple up.
92lxsleeper
Apr 4, 2010 08:54 AM
fastshift
Jan 8, 2010 05:59 AM
marks97el
Transmission & Drivetrain
May 12, 2009 12:35 PM
GSR936
32
Dec 7, 2008 08:42 AM
deeweezy187
Mar 3, 2007 02:24 PM
