Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Pilot 2010 intermittent code P0847
Old Oct 11, 2015 | 04:14 PM
xela9000's Avatar
Default Pilot 2010 intermittent code P0847
Check engine is on and "D" blinks on my wife's 2010 Pilot. The problem is intermittent. It happens, stays for couple of days and then goes away just to appear again after several days. It seemed to go away after I retightened a fuel cap. Could it be related or just a co-incidence? I checked the error code. It is P0847 - 3rd Clutch Transmission Fluid Pressure Switch. If it is not a fuel cap, the next logical step, I think, would be replacing the switch. Hence is another question. There are three oil pressure switches on the part diagram: two of the same model (11) and one different (12). Which one is the 3rd Clutch Transmission Fluid Pressure Switch? Reading replacement instructions in Service Manual, I guess it is a bottom one (12). Can you please confirm if this is correct?
Old Nov 2, 2015 | 07:54 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Pilot 2010 intermittent code P0847
Did you add any transmission fluid or at least check the levels?
Old Nov 9, 2015 | 03:06 AM
xela9000's Avatar
I did check the level. It was normal. After tightening the fuel cap again, check engine does not light up any more. Strange. I still don't know if it was a coincidence or this code is somehow related to the leaking fuel cap.
Old Nov 10, 2015 | 05:00 AM
speedlever's Avatar
It's probably the same as on my 2006 Pilot.
Old Nov 10, 2015 | 09:22 AM
jimlaw3's Avatar
12 is the 3rd pressure switch,I have installed many.
Old Sep 27, 2020 | 10:06 AM
rteest93's Avatar
Can you tell me if the switch 12 is on the passanger side or the drivers side of Honda Pilot?
Old Sep 27, 2020 | 12:47 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The transmission is on the driver's side.
The 3rd clutch pressure switch has one wire and a blue connector.
ZamboniDude
Acura TSX
Jan 20, 2019 03:40 PM
N1civicSi
Oct 13, 2013 04:45 PM
andhoova
Sep 3, 2010 04:38 AM
hondacurab16
Sep 21, 2005 11:00 PM
