02 Honda accord LX - RPM drop on startup & Engine clunking
My car I notice has a rhythmic clunking noise now, one that isn't what you would typically hear in some cars. It can drive with the clunking noise too I don't notice any apparent threat to my car just the noise being much more louder than your typical rhythmic noises from the engine bay. Along with it I notice when I startup my car my RPMs will go to the normal around 1,000RPM idle but drop to around 250RPM after 1 second of being on seeming like its going to stall and comes back up to a little over 1,000RPM idle.
Now before any of this about 5 days ago I had a check engine light (See Picture for troubleshooting of CEL). The thing is before I could even do any fixes my check engine light turned back off so I ignored anything that was on the check engine light list, could any of the things on it possibly have to do with my current problem? Thank you.
Number two cylinder miss. Sounds like the number two cylinder is dead. Either no fuel, spark or compression in the cylinder. Pull the spark plug first...check it out. If you have spark...then suspect a fuel injector(Or lack of signal to the injector). If theats a no go...then do compression test.
dko30133
Honda Civic (2001 - 2005)
Oct 16, 2017 07:24 PM
FreddyCarbs
Jun 4, 2013 06:38 PM
crowdcor225
Mar 19, 2013 07:41 AM
