FT-2000 honda s2000
Old Oct 6, 2015 | 06:17 PM
ef8b16's Avatar
Default FT-2000 honda s2000
Got the car back in April 2009. car had 66158 miles on it. Now need a bigger car so looking to trade my ap1 for a 4 door truck of equal value as my car.
Or if you wanna make an offer go for it.
Text me for any questions at 9493519402
The list
2000 Honda s2000.
135000 miles.
Berlina Black.
Clean Title.
Exterior.
Paint is 8.5 out of 10.(door dings here and there)
Fenders got roll and pull to clear 255 not the best work but the get the job done.
J's racing half lip style.(Polyurethane)
Front bumper has paint chips/cracks from flexing.
Rear 1/2 roll/pull.
Rear bumper tab relocated.
Top was replaced 3 years ago with glass window.
Interior
8 out of 10 only bad part is the driver side carpet and wear on driver seat.
Stock other then alpine head unit and mugen shift ****.
Suspension
17x10 38 offset silver rpf1.(less then a year old)
Nitto 555 255/40/17 all around. (Same aged as wheels)
Apexi n1 exv coilovers.
Front bushing have been replaced with energy bushings. (Done at the same time as wheels)
Megan X front tower bar.
Beaks rear lower tie bar.
Rear bearings,hubs and are extended studs.(same time as wheels)
Engine
Engine was replaced with a jdm swap at 122647 engine and transmission.
New parts installed when swap was done.
Oem timing chain tensioner.
Oem water pump.
All the hoses from water pump/oil cooler replaced with Oem ones.
Oem pressure plate.
Oem trow out bearing.
Oem pilot bearing.
Comp clutch sprung 6 puck disc.
Aasco billet aluminum light weight fly wheel.
68mm bdl throttle body.(port match to intake manifold)
Oem intake manifold gasket.
Aem cold air intake. (Painted wrinkle black)
Invidia test pipe.
Parts that will be include with car.
Og transmission.
Engine block with arp rod bolts.(needs new bearings crank is in good condition)
Head with supertech valve train.(missing rotating assembly)
Extra intake manifold with egr delete plate.
Jdm ecu and engine harness.
Arp head studs.
Og cat.
Oem air box.
Apexi cat back.(stops at the rear axle with a v band flange still need to do the rest)
<a href="http://s473.photobucket.com/user/ef8b16/media/Mobile%20Uploads/IMAG0579_zpst2cneedz.jpg.html" target="_blank"><img src="http://i473.photobucket.com/albums/rr92/ef8b16/Mobile%20Uploads/IMAG0579_zpst2cneedz.jpg" border="0" alt=" photo IMAG0579_zpst2cneedz.jpg"/></a>
<a href="http://s473.photobucket.com/user/ef8b16/media/Mobile%20Uploads/IMAG0798_zpsirztcbiu.jpg.html" target="_blank"><img src="http://i473.photobucket.com/albums/rr92/ef8b16/Mobile%20Uploads/IMAG0798_zpsirztcbiu.jpg" border="0" alt=" photo IMAG0798_zpsirztcbiu.jpg"/></a>
<a href="http://s473.photobucket.com/user/ef8b16/media/Mobile%20Uploads/IMAG0797_zpsexenf64a.jpg.html" target="_blank"><img src="http://i473.photobucket.com/albums/rr92/ef8b16/Mobile%20Uploads/IMAG0797_zpsexenf64a.jpg" border="0" alt=" photo IMAG0797_zpsexenf64a.jpg"/></a>
Old Oct 6, 2015 | 07:52 PM
toyomatt84's Avatar
Sanji
Default Re: FT-2000 honda s2000
Please see here: Honda-Tech - Announcements in Forum : Honda-Tech Marketplace
turbos2k
Sep 20, 2016 07:14 AM
ef8b16
Oct 6, 2015 07:52 PM
Nermin
Nov 11, 2012 10:28 PM
96teggynonVtec
Oct 23, 2011 02:16 PM
96teggynonVtec
Oct 17, 2011 06:07 AM
