Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Accord V6 Radiator Replacement
Old Oct 4, 2015 | 05:41 PM
ashtonallen's Avatar
Default 2007 Accord V6 Radiator Replacement
Does anyone know if there is a detailed DIY for replacing the radiator on 2007 V6 accord? Thanks!
Old Oct 5, 2015 | 04:26 PM
poorman212's Avatar
Default Re: 2007 Accord V6 Radiator Replacement
It is about as straight forward as it can get
I'll hit the high points.....pull to cover above the rad....drain coolant, remove hoses - auto trans has the trans cooler hoses, there are some connectors for the fan motors and some for wires and ac lines.....remove the upper rad "coushions/brackets".....lift rad out of the car.
Can't remember right now but I'm pretty sure the fan motors can stay attached to the rad....if I'm wrong, won't be the first time my memory failed me, you might have to remove one or both to have room to lift it out.....if you do remember the lower mount/screw/bolt is a "slip" type and does not have to come all the way out, just loosen it a bit, remove the top two and the motor(s) will lift out.
Old Oct 7, 2015 | 05:33 PM
poorman, thank you for the helpful post.
londonsupra
Jun 30, 2006 05:22 AM
vettman
Aug 5, 2005 06:07 AM
GKIN
Aug 21, 2004 05:32 AM
dchi_t
May 7, 2003 11:42 AM
