2001 Honda Civic Ex - flashing dash and turn signals?
About 2 weeks ago my daughters 2001 Honda Civic EX would not start. It had the normal clicking of a dead battery. We jump started it and took it to a local battery store where they load tested the old battery and it tested bad so we replaced the battery. It has been fine for about 2 weeks and she drove it last night with no issues. She tried to start it 3 hours after normal operation and it wouldn't start. I was thinking I had a bad alternator and that the battery had just died because it had worn down over the 2 weeks of poor alternator charging. When I went out to work on it this morning the dash lights and both turn signals just flash and it is clicking up under the dash near the fuse box? This is without the key even being in the ignition??? I hooked the charger up to it and the battery says it was nearly at full charge? When I try to start it the starter isn't turning over at all but I still get the clicking of the dash lights and the turn signals are still flashing. When I take the key out of the ignition the flashing still continues? I have disconnected the battery and reconnected hoping for something to reset but no luck. When I re-connect the battery the turn signals start blinking immediately and the dash starts blinking again too. I did verify twice that the emergency flashers are not on. Any guidance or ideas would be greatly appreciated!!
Blackhead
Honda Civic (2006 - 2015)
Nov 2, 2018 12:46 PM
multi_2009
Jul 31, 2017 12:18 PM
attml
Honda Civic (2001 - 2005)
Oct 4, 2015 05:48 PM
