91 integra ALB ( anti lock brakes ) Help
Old Oct 4, 2015 | 08:54 AM
Russian21's Avatar
Icon5 91 integra ALB ( anti lock brakes ) Help
I just got a 91 integra shell and it has the ALB system on it. If I switch it out with an ecu that didn't have it previously would that make it not function, and if I want to remove it do I have to use a non ALB brake booster or just leave it that same after removing the ALB system? Lastly is ALB different from ABS? I've seen some say ABS and other ALB. Just need to clarify before i start working on anything.
Old Oct 4, 2015 | 09:50 AM
MotorMouth93's Avatar
10 Year Member
Default Re: 91 integra ALB ( anti lock brakes ) Help
The ABS is completely separate from the engine/ECU. So yes, you can change the ECU without affecting the ABS.
Here is another thread about removing the ABS.
Old Oct 4, 2015 | 12:28 PM
Russian21's Avatar
Thanks.
Old Oct 5, 2015 | 04:54 PM
tony_2018's Avatar
Fish Twig
abs has its own ecu, no need to worry.
Cruiserdude
May 13, 2019 08:20 AM
Tegra
Nov 13, 2004 02:23 PM
Kamil
Jan 31, 2003 01:13 PM
RacnGSR
Aug 15, 2002 02:02 PM
