koni yellow/gc height?
what's up guys! I just ordered 430f/350r gc springs for my 95 hatch & I was wondering will they go LOW? anyone have there's sitting at lowest setting? I believe they're 7inch springs. also.. what's the difference between the koni yellows & the koni yellow sports? a rep from ground control said he was building the springs to fit the sports.
They will go functionally low. If you want stance retardation, then you're in the wrong section. We do actual, functional tech around here. For "dragging rail" stance bullshit, you want the appearance forum.
with 7'' springs it will get pretty low, but you have to worry about the front UCA's. I can promise you the rates are too low to slam the car.
however if you just want to close the gap you'll be ok.
I ran 650's in the front when I slammed my civic. Just an example.
