Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Alternator replacement problem
Old Oct 3, 2015 | 10:25 AM
OttenVT03's Avatar
Default Alternator replacement problem
2008 Accord LX 2.4L
Miles: 153K
Maintenance record: poor
Disclaimer: My girlfriend''s car, maintenance wasn't a priority, ever
The car started making a funny noise at start up and the engine began shutting off randomly after 15-20 seconds and occasionally when coming to a stop. Went to Auto Zone and had the alternator and battery tested. They said the Alternator is bad and the battery will need to be replaced soon.
Purchased a new alternator and replaced the bad on, also replaced the serpentine belt. Replacing the alternator was a challenge in itself and I needed an extra hand to get the belt on. Anyway, to replace the alternator I had to remove the cooling duct, disconnect the cooling hoses (lost a lot of antifreeze, added a gallon), air hoses, disconnect some wiring harnesses, and remove the exhaust manifold heat shield.
After reassembling everything, I tried to start her up. She cranks, fires, and turns over flawlessly. However, when it turns over it runs for about 1-2 seconds and then shuts down every single time. Everything sounds great but it won't run. Unfortunately, I had to reassemble everything the next day as I had to wait over night for a new serpentine belt. My first thought is that I failed to connect a certain hose or wiring harness. If searched several times and cannot find anything that looks out of place or is disconnected. Next thought was a fuel pump but why would changing an alternator through out the pump? I'm at a lose now and am looking for any helpful advise as I need to get this running by Monday afternoon. Any help is appreciated, thank you.
Kris
Old Oct 4, 2015 | 06:27 PM
lazlong's Avatar
Default Re: Alternator replacement problem
It can sometimes damage electronics when they get just a trickle of voltage. That being said, put a code reader on it and post the exact codes it's throwing.
Old Oct 5, 2015 | 03:48 AM
salcuta88's Avatar
How's your fuel pump? What about the air filter?
Restricted air flow will make it shut down, but that would take a very very dirty filter.
If the fuel pump pumps badly, the engine may not be getting enough gas.
A similar issue I had in my dad's truck was that there was lots of rust in the tank that would block the intake of the fuel.
dohc_profile
May 31, 2006 06:45 PM
Fook_me_honda
Mar 22, 2006 04:32 AM
christianscrx
Feb 23, 2006 12:56 PM
wizzards581
Jun 14, 2003 01:41 PM
