1992 Accord: Low air flow out of vent...
Old Oct 3, 2015 | 09:41 AM
nwerner's Avatar
Default 1992 Accord: Low air flow out of vent...
...that's the issue. Here's the story:
About 6 months ago the fan blower motor was starting to go out (some days it would start, others it wouldn't). Knowing it was the motor, I purchased and installed the new motor within the old blower assembly. I cleaned the entire assembly prior to reinstalling it in the car. When i started the car, the motor was working but the air flow out the vent was really low.
Now that winter is around the corner, I decided to try and tackle this issue. Thinking it was the new motor, I purchased a functioning, used blower assembly (all stock parts). I installed the 'new' used assembly, but I'm still having the same issue.
Thanks for reading, thoughts?
Old Oct 3, 2015 | 10:20 AM
HonBeer's Avatar
Default Re: 1992 Accord: Low air flow out of vent...
How do you "know" it is the motor and not the resistor or a wiring issue? Sounds like your throwing parts at it without diagnosing the fault properly. Just sayin....
Old Oct 3, 2015 | 10:21 AM
v4lu3s's Avatar
RTFM
i would check the resistor and also make sure vents are not clogged or tubing not leaking inside the dash.
Old Oct 4, 2015 | 04:45 AM
poorman212's Avatar
I'll guess the first replacement motor (aftermarket), you had to cut and splice the wires to the new motor.
Then with the used one, you had to undo the splice and then splice into the used factory motor.
Usually these motors are bi-directional meaning they will spin different directions depending on which wire is "hot" (voltage) and which one is ground.
So for giggles....try switching the wires you have spliced.
The number of times I've read/seen this same type of issue........the blower motor is spinning in the wrong direction.
Old Feb 14, 2021 | 08:14 AM
Skyler Terry's Avatar
this is correct. I know because I just rewired my blower motor and now she’s blowing good. Thanks a ton
Old Feb 14, 2021 | 10:25 AM
99stockcivic's Avatar
Nice tip! Writing that one down.
mkfrl
Nov 14, 2018 04:45 PM
Jrimel2208
Feb 2, 2017 02:55 PM
lphthephunk
Aug 9, 2014 05:49 AM
Jericho574
Honda Civic (2001 - 2005)
Jun 15, 2013 05:24 AM
daidilus
Dec 10, 2004 04:16 PM
