97 accord shuts down at 1500 rpm
Old Oct 2, 2015 | 08:13 PM
genesun56's Avatar
Default 97 accord shuts down at 1500 rpm
46 years as a tech but retired for last 12 years.
my sons accord was running fine but then shut down. I have checked everything I know to. Belt is fine, all injectors are pulsing and it's firing on every hole. Fuel pressure is fine.
Starts intermittently but only runs on two holes but its not always the same two.. If it does start it will go to exactly 1500 rpm and then shut down like you turned the key off.
Son said it made a odd high pitched whine a few minutes before it started this problem.
Have been told these things are notorious for distributor failure at high mileage.
Its a LX non vtec
Any ideas would be greatly apprecated.
Thanks
Gene
Last edited by genesun56; Oct 2, 2015 at 08:34 PM. Reason: more info about engine series
Old Oct 2, 2015 | 08:46 PM
holmesnmanny's Avatar
Default Re: 97 accord shuts down at 1500 rpm
Atleast take the cap off and take a good look inside. See if you see any debris.
You say the belt is fine, but maybe it slipped a tooth or two. Check the mechanical timing.
Old Oct 6, 2015 | 05:06 PM
genesun56's Avatar
new distributor, cap, rotor, wires, plugs, and coil. Checked the mechanical timing and it's on the money. scanning doesn't reveal any codes other than a EGR code.
Old Oct 7, 2015 | 07:32 AM
therest's Avatar
I'm not very experienced but I do know that the ignition switch on these Accords go bad, and that sounds like a symptom of a bad one. Other than that maybe IAC? IAVC?
DelSolAntrax
Jan 8, 2014 04:51 PM
CD5B2
Jan 19, 2013 09:53 PM
Ju664l0
Jun 17, 2010 04:15 PM
thatguysstuff
Feb 3, 2010 11:02 AM
RIZOBIZERT
Mar 15, 2008 04:42 AM
