CA 1999 Acura Integra LS 69k Original Miles Clean Title Clean Carfax Smog Ready 1 Owner
1999 Acura Integra LS 2door coupe/hatchback. Original lady owned, purchased from Santa Monica Acura and maintained ONLY at Santa Monica Acura.
-1 Owner, elderly lady owned original california car
-100% matching vin#'s on motor/transmission/body panels/doors etc.
-69,621 Original miles
-Clean title in hand
-Clean carfax in hand
-Smog ready as of September 23, 2015
-Registration good until September 2016
-Flamenco Black pearl original paint in excellent condition
-Tan/beige cloth interior In excellent condition (non smoker car/no pets)
-4 cylinder 1.8 liter gas saving engine, absolutely NO problems, NO LEAKS of any kind!
-No check engine light/abs or srs lights on. Everything functions properly.
-5 speed standard transmission
-Original factory aluminum alloy 15" wheels in mint condition with plenty of life on the continental tires.
-Anti lock 4 wheel disc brakes
-Power steering
-Standard driver & passenger airbags
-Power door locks/power windows/power side mirrors/cruise control/power moonroof/Viper alarm keyless entry system
-ICE COLD Air conditioning*
-No aftermarket modifications, all original besides the viper alarm
-All maintenance done through the Santa Monica Acura dealer with receipts to prove:
-Transmission fluid change, oil change, new clutch and resurfaced flywheel, power steering fluid flush, new axle seals, new axle boots, new oil pan gasket, new air filter, New timing belt & drive belts, new water pump, new thermostat, new radiator cap, all coolant hoses were replaced with new, coolant flush, new spark plugs, new distributor cap & rotor, valve adjustment performed to factory specifications, new valve cover gasket, new rear trailing arm bushings. Everything totalling $7000 with receipts to prove.
This car needs nothing, just a new driver. Buy with confidence. The Bluebook value is $4,000 , and the carfax states it is worth $1,340 more than bluebook. That doesn't even include the $7,000 in maintenance this car has received from the Acura dealer using only factory original equipment parts.
Located in Oxnard, CA 93033
$5,999 OR BEST REASONABLE OFFER
no trades, no payments.
thadon805
Nov 15, 2017 02:53 PM
thadon805
Oct 13, 2015 05:40 PM
thadon805
Oct 5, 2015 04:12 PM
