2000 civic dx d15b non vtec swap
Ok so I just picked up a d15b non vtec with around 50k the distributor cap got busted during shipping it looks like
What dizzys work for this? I have a d16y7 as the donor motor would it be better to buy a new cap or is it possible to run y7 cam dizzy and cam gear?
Sorry been trying to research this but haven't seen anything that helps on other forums
if your distributor physically bolts to the head, it will work. if it does not, you can swap its guts into the casing of the broken one.
You can go to Majestic Honda - The Internet's #1 Honda Automotive Parts Store and make sure the part numbers match up for what you're wanting to do.
Did you get the motor from an EF?
88EFsedan2
Jan 23, 2012 10:05 AM
efprojectboost
18
Dec 13, 2007 07:45 PM
