CT 1991 Honda CRX SI B16A TURBO
91 Honda CRX SI
Sunroof
Japan Spec B16a DOHC VTEC engine swap
Rebuilt s1 tranny 2000$ alone (extremely solid tranny).. 93 integra axles (Lifetime warranty on axles/NAPA have receipt) and intermediate shaft. NO GRINDS! NO GRINDS!, always used Honda MTF
Skunk2 adjustable cam gears (blue)
aluminum valve cover.. shines (polished)
aluminum spark plug cover (blue)
unorthodox silver racing pulley.. running alternator that's it.
Motegi mr7 17in white rims with khumo tires practically new condition. (driver side rear has slow leak/do to sitting). (with lock and key). Also comes with a spare white rim (very similar to the Motegi's)
Mini ram turbo manifold (well made)... plus have a DC Sports header included
xs power to4e 57 trim turbo 50/63
JRC (Johnny Race Car) 8 inch intercooler.. very well made, they don't make intercoolers like this anymore. (in perfect condition)
Tial 38mm wastegate (blue).. (exhaust vented under motor)
2.5 MS charge piping with t-bolt clamps/couplers
3 inch SS downpipe/flex pipe V-banded to Full 3 inch SS k-teller exhaust
Greddy type-S knock off BOV also comes with another type-s BOV (brand new in box)
JK Motorsports traction bars (no wheel hop)
Aluminum half radiator
Slim Fan (on switch in the car)
Autometer Phantom.. Boost, water temp, volts, oil pressure, and 5inch tac with shift light. gauges (2 on pillar, 2 in gauge cups on dash) sitting in the car you would think your in a stealth fighter jet lol
Golden Eagle vacuum log and fittings (black). comes with extra fittings
Oil Line kit
DSM 450 Injectors
Distributor Kings 0bd1 Dizzy (new)
obd0-obd1 conversion harness
manual boost controller
Chipped obd1 ECU with dattalogging kit and Dizzy adapters running crome pro. street tuned conservative.. also comes with pr3 ECU! to put car back to NA if wanted
In car wideband o2 sensor with digital display.. can be pulled out and put in ANY vehicle for street tuning. runs off cig lighter
Projector Headlights w/ BMW style Halo (will come with another set of projector lights AND the stock OEM headlights)
Clear side markers with LED Lights matching projector headlights
6000k H.I.D.'s headlights
LED turn signals, bumper and corner lights are clear.. bluish white (every light matches) Also comes with original OEM Bumper lights
Front and rear polished strut braces
Battery relocated to trunk with kill switch on Breaker on the box /fused
Hasport shift linkage
energy suspension shifter bushings
short shifter with type R **** (knockoff)
white face gauges
Full Mugen style full body kit. Front bumper, Rear bumper and side skirts (with extra Blitz front bumper)
z3 fenders
rear mid wing with brake light
Newer speakers in back..
Pioneer Head unit w/ active motion display
Car is wired for Subwoofer if need be, comes with Monster RC cables
I'm sure there's plenty more parts missing of this list which i just cant remember.. every time you look at the car you'll see something new!
I have pretty much every receipt for the car (inch thick booklet lol). so you'll know just how much is invested. I am the 2'nd owner of car, was bought from older lady, and have her reciepts as well.
INCLUDED FOR FREE!
Comes with another front bumper, and another set of projector headlights. also the original OEM headlights (3 sets of headlights) and original OEM bumper lights, DC Sports Header, PR3 ECU, data logging kit, new in box oil cooler, extra bolts/nuts, Forced Induction booklet, 2 Service Manuals, extra gaskets and fittings, a bunch of stock oem parts, brand new Hood latch pin's with cables and a box of extra SS pipe bends/straights. ALL INCLUDED!
car dynoed 247 whp on 7 pounds of boost. with dyno sheet to prove.
The car has been sitting for nearly 6 years.. drove fine when i pulled it in the garage and has sat there ever since. body has rust in the rear fender wells (Body condition is ok considering the year, has its flaws), paint/clear coat on car is fading. Rear bumper has seen better days (cracked, but made of fiberglass so reparable). ( Realy just needs paint and body work).
I recently just put a battery in the car and it fired right up! no problems.. took it for a ride around quick and everything seems ok.. car is smoking some probably due to the turbo seals needing to be replaced from sitting so long. but it does run and drive just fine! Car is VERY VERY FAST!
Car needs to go.. sick of seeing it just sitting.. I have owned this car since high school (we go way back lol) thousands and thousands have been invested in the car.. asking 4500 obo (shoot me an offer!). cars worth WAY more then that just piecing it out.
Vehicle is over 20 years old so title is not necessary only Bill of Sale. You can text or call me at 860-478-4607. The car is located in the Hebron/Bolton (at the end of 384 towards towards route 6) Thats in central Connecticut.
Give me a shout!
Sunroof
Oil Line kit
DSM 450 Injectors
white face gauges
z3 fenders
INCLUDED FOR FREE!
Give me a shout!
