oil light
Ok I have a 92 honda prelude S. My oil light is on and won't go off. I checked oil, oil pressure, rest the ecu n battery. It's bn a good long while since I had a honda but I haven't ever experienced any problems like this. I'm open 2 any info on this f22a motor. Also anybody have a fuel/temp gauge??? Digital kinda sux
I believe that light gets triggered when the wire to the oil pressure switch see ground. I'd try unplugging it and see if the light goes off. If so, it sounds like the oil pressure switch may just be shorted internally (normally open with oil pressure) if the light stays in after unplugging it, check the wire for a short to ground.
This is assuming your oil pressure is in fact correct.
sporkcrx
10
Jul 27, 2003 11:54 AM
