FS H22a Swap p13 Ecu, hcp mounts into eg
Old Sep 29, 2015 | 01:20 PM
JdmCIVIC853's Avatar
Icon4 FS H22a Swap p13 Ecu, hcp mounts into eg
H22a swap is complete swap comes with P13 ecu, shift linkage, header(ebay) and
harness is for h22 swapped into an eg also have the hcp mounts for eg/h22 swap but they need new bushings....
The Motor Needs one new rod bearing.The original car with the swap flipped over and it ran upside down and spun a rod bearing.
It ran when i pulled it out just has a slight knock.
Trans is still in good condition, preformed leak/down test and a compression test, all was good compression was great.
I would like to get 750 for everything, willing to part out everything except the swap...
Old Sep 30, 2015 | 06:42 PM
em2guy913's Avatar
Default Re: FS H22a Swap p13 Ecu, hcp mounts into eg
Where you located at?
Old Oct 3, 2015 | 10:22 PM
Southeast Missouri
jakfrost84
Northeast (Sales)
May 18, 2017 04:31 AM
jakfrost84
May 16, 2017 08:08 AM
JdmCIVIC853
Dec 15, 2015 09:06 AM
low430
Sep 11, 2005 06:37 PM
pane93civhb
Apr 26, 2005 10:21 AM
