93 Civic hatch - Contemplating fixing this body rust. Any advice
Old Sep 27, 2015 | 07:11 PM
averyvm's Avatar
Default 93 Civic hatch - Contemplating fixing this body rust. Any advice
Under-side right.
Top-side left
Donor car 1
Donor car 2
93 Honda Civic Hatch
I got some rust where the hatch meets the body. This would be my first time welding in a patch panel.
Old Sep 27, 2015 | 07:41 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 93 Civic hatch - Contemplating fixing this body rust. Any advice
That'll be a fun place to weld. I'm sure your car's structural rigidity will appreciate it, though I'm sure everyone would appreciate step by step pictures as you go along.
Old Sep 29, 2015 | 09:57 AM
24TEN's Avatar
PHANTOM MENACE
Sadly my car is suffering from rust in the same spot but is no where near that bad. I'd love to see someone attack this particular spot.
Old Sep 30, 2015 | 03:10 PM
joey1320's Avatar
Honda owners need to realize how easily they have it when it comes to rust issues.
I don't do body work, but honestly, its only metal - it can be fixed.
Here, how about finding a '38 VW that has been hacked, welded, cut, f'd and left for dead in the fields of Lithuania, only to rebuild it better than original. Yeah, your rust is easy to fix.
http://www.thesamba.com/vw/forum/viewtopic.php?t=340552
Old Sep 30, 2015 | 10:25 PM
Jimi Hondrix's Avatar
TheSamba.com :: View topic - VW38 found in Lithuania
Difference being that 1938 is the first year production of the VW bug and that car is worth a shitload. When a 6th gen civic gets rust repair it probably cost as much as the value of the car..and that value just get keeps going down. So, it's a question of incentive no matter how easy one is to repair compared to the other.
Old Sep 30, 2015 | 10:53 PM
tony_2018's Avatar
Fish Twig
Of course we have it easy.
Old Jul 13, 2016 | 04:08 AM
averyvm's Avatar
No brace left
No brace right
Brace in left side
Brace in right side
Brace in center
We're getting there. bump
Old Jul 13, 2016 | 08:38 AM
eghatch9295's Avatar
Stancetard Hate Monger
nice.
Old Jul 13, 2016 | 09:56 PM
24TEN's Avatar
PHANTOM MENACE
Happy to see you came back to update this thread.
Old Aug 6, 2016 | 05:31 PM
averyvm's Avatar
Still working on it. This is my first time fabricating a patch panel. bump
Old Aug 31, 2016 | 07:51 AM
averyvm's Avatar
Still working on getting this roof skin piece ready for final installation.
I've used POR-15 degreaser, metal prep and paint
Seam sealer applied
Here I'm showing an example of one the gaps I filled.
Before
During
After
I'm a little worried about this gap. I'm not sure if I can just fill it up with
seam seal. Maybe I need to place some sheet metal in there. Any advice is
appreciated.
bump
Old Aug 31, 2016 | 08:09 AM
ShinsenTuner's Avatar
No Jodas
looks like it was deformed from removal, I'd just rework the area with some force to get the mating surfaces to touch again.
Old Oct 24, 2016 | 04:11 PM
averyvm's Avatar
Thanks Shinsen
Old Oct 24, 2016 | 07:38 PM
needs to be filled with metal/weld. too big to seam seal.
Old Oct 28, 2016 | 10:34 AM
averyvm's Avatar
Thanks for the assistance.
Here is where it stands now.
Tack welds
More tack welds
Starting to grind the welds down
bump
Old Oct 31, 2016 | 09:16 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Very nice! That's an ambitious project.
Old Nov 14, 2016 | 01:52 PM
averyvm's Avatar
Old Nov 14, 2016 | 02:16 PM
24TEN's Avatar
PHANTOM MENACE
Well I'm excited LOL
Old Nov 19, 2016 | 02:47 PM
averyvm's Avatar
First time ever mixing body filler.
Applying filler
Seam sealer
New clips for roof trim. ttt
Old Dec 22, 2016 | 04:10 PM
averyvm's Avatar
Second coat of body filler
Mixing glazing putty
Applied glazing putty
Alot of sanding later
Wrapping up a different type of gift. Bump
Old Dec 23, 2016 | 08:08 AM
24TEN's Avatar
PHANTOM MENACE
Good job so far, can't wait to see it finished!
Old Dec 23, 2016 | 03:32 PM
94EG8's Avatar
Seagull Management
You should have swapped the whole roof skin. The roof flexes and there's a pretty good chance the fill will crack, plus it's really hard to weld it and not have it warp even tacking here and there and cooling it off with air between welds.
Another tip: Use fiberglass first on something like that before the bodyfill, it's waterproof and it's a lot less likely to start blistering in 6 months to a year.
Old Dec 29, 2016 | 10:31 AM
averyvm's Avatar
thanks for the advice. I realize later that it would've probably a been better to buy a new roof skin but it was difficult to source the new roof skin.
Old Dec 29, 2016 | 04:00 PM
94EG8's Avatar
Seagull Management
There's nothing wrong with using a used roof skin, you just should have used it all of it is all.
Old Jan 10, 2017 | 12:12 PM
averyvm's Avatar
I hear what you're saying. It was tough finding another used hatch to cut up at reasonable price.
