Help 1997 honda accord 2.2 16v engine turns, however not start, so if I pumped the ac
honda accord 1997 2.2 16v when starting threatens work and dies, after a few seconds, however if it is pressing the accelerator after a few seconds works normal and not die again, but after switching off and on again, threatens to run for seconds and dies again, only works if it is pressing the throttle several times and fast, then gets normal, the problem starts every time when starting when you turn off the engine, replaced parts, new fuel filter, new fuel pump, new full distributor, ignition cylinder checked and okay, and the problem persists, the vehicle has good pressure in fuel flute, has spark in the spark plug wires, but it works and dies, then I realized that when starting the vehicle, the fuel nozzles pulsed and stop after a few seconds, and therefore the vehicle worked and died, the stopped fuel nozzles of work, however to start the vehicle by pressing the throttle quickly then worked, then the question why, the vehicle stops running the fuel nozzles when starting the engine, and starts pressing the throttle several times, as in carbureted vehicles, I realized with pulse test fuel nozzles not stop working if you remove the spark plug wires at this time the vehicle should function, someone already picked up this problem
If you could possibly break that up and make it more clear about what youre asking. Might get a better response. I tried to read it...then gave up
Dear friend, I mean that, when I turn on the engine, it works and die just few second after the engine get up and running, but if I pumping the accelerator fast, the same time I turn on the engine than it work. what i fond, was that, the fuel injectors start and stop, it seems be the problem of the engine stop work, but pumping the accelerator the engine works fine, I hope you can understand now.
cwarnold77
Apr 5, 2017 01:01 PM
