99 accord instrument lights out
I purchased a o9 accord exv6 and the dash illumination lights don't come on when the headlights are switched on. It's dark and I can't see the speed I'm going. Everything is stock with no modification. My radio light work and ac control lights work, they even dim with dimmer ****. I checked the fuses and all fuses are not blown. I also read that the multiplex could be bad, and there is a way to bypass it by using a paper clip. I tried that trick but the lights are still off. If the multiplex trick doesn't work, what can be the problem? Please help and also thanks in advance.
BSmoov83
Oct 2, 2012 02:38 PM
stanleykennedy
Jan 13, 2005 10:54 PM
