Suspension & Brakes Theory, alignment, spring rates....
Spoon calipers 4x100 conversion
Old Sep 27, 2015 | 05:27 AM
KoRn_vIRuZ's Avatar
Default Spoon calipers 4x100 conversion
Hi everyone,
I am trying to install a set of Spoon calipers on a 4x100 bolt pattern car. I read about Mini Cooper rotors but didn't like the fact that they were too small, had overly large stud holes and the retaining screws didn't fit.
I researched and found MG ZS 180 rotors solved all of these problems, so I bought some. The thing is the friction surface is a little too large. I.e. the brake pad does not cover the entire rotor, like in this picture:
I wanted to ask if this can cause a problem or not? Thanks!
Old Sep 28, 2015 | 01:39 PM
Reyes's Avatar
Default Re: Spoon calipers 4x100 conversion
Does the pad hang over on the outside of the rotor? If not and the entire pad surface is on the rotor, you will be fine. If it hangs over, you will just get uneven pad wear.
I have been using the Mini Copper rotors on my track car for a few years and have never had any issues.
Old Sep 29, 2015 | 03:39 PM
KoRn_vIRuZ's Avatar
Thanks for the reply Reyes. The pads sit entirely within the rotor's friction surface. The 'problem' is the opposite, the not does not cover all of it. On the outside edge there are like 2 mm of rotor left, which I believe is normal. On the inside edge however, there are like 5 mm left.
Old Sep 29, 2015 | 08:20 PM
Bently_Coop's Avatar
Steve at Heart
In the sticky at top of this section your question is answered on the first page. Look for Libertariat's post's.
https://honda-tech.com/suspension-br...egras-3044628/
Old Oct 21, 2015 | 09:39 AM
Ribbon's Avatar
hi guys..
what size are the mini cooper discs?
Old Oct 21, 2015 | 09:41 AM
Ribbon's Avatar
oh and sorry, what size are the MG rotors?
Old Oct 22, 2015 | 11:11 PM
.Grimace's Avatar
footwork mastery
Many are designed like this to leave a gap there. You can run a 2 piece rotor because you need that extra space for where it attaches. Even a brand new wilwood kit will have that if used without a 2 piece rotor.
ITR Factor
Jan 20, 2004 06:21 PM
ABTDer
Jun 10, 2003 01:17 PM
shinchan
Mar 27, 2003 11:12 AM
Rboosted717
Sep 24, 2001 03:43 PM
