Stiff PCV valve hose.
Old Sep 24, 2015 | 03:02 PM
dgdarien's Avatar
Default Stiff PCV valve hose.
I barely passed a smog check not too long ago, and the tech said that I should replace the hose connecting the PCV valve to the intake manifold because it was really stiff.
This hose is coming up on 15 years old but I understand that this tubing needs to be stiff to withstand some of the vacuum pressures.
Can this actually affect any smog related performance, or was the guy making things up as he goes?
#4 in diagram. Part# 17131-P2J-000
Old Sep 24, 2015 | 03:59 PM
tony_2018's Avatar
Fish Twig
Default Re: Stiff PCV valve hose.
oem hoses aren't stiff, they are firm but not stiff. Its probably past the point where it could probably fall apart.
Old Sep 24, 2015 | 04:58 PM
dgdarien's Avatar
Well it is pretty stiff, but not breaking or cracking. I managed to flex it a bit and it didn't show any signs of distress. Could it still somehow affect emissions testing? I am considering checking/replacing the PCV itself.
Old Sep 24, 2015 | 05:57 PM
tony_2018's Avatar
Fish Twig
hmmm....there really isnt anything monitoring bllowby
Old Sep 24, 2015 | 06:12 PM
Jimi Hondrix's Avatar
That hose needs to be fairly stiff so it doesn't pinch off, especially at the elbow where the PCV valve attaches.
Old Sep 24, 2015 | 10:13 PM
MisereNoire's Avatar
I did my PCV hose recently, and what I found was this:
The hose was stiff, but not yet cracking.
The grommet-style end that presses through the IM was rock hard, and did not allow a PCV valve to seat snugly anymore. The other end of the hose was oil impregnated and was allowing air/oil leakage past the breather chamber box nipple.
So basically, when the hose has reached the point where it starts to swell from oil permeation, and the oil and heat exposure causes the hose to harden, then the hose is no longer performing to satisfaction and should be replaced. (At this point it is extremely prone to cracking at the ends, and can dirty up your engine with leakage).
As for affecting smog performance...not likely unless it breaks entirely (which should make it run cleaner...not dirtier..but only marginally so. They just frown on blowby gases being vented to atmosphere), and even then the inspector is just being a nitpicky representative of the state, which has it's collective head up it's ***.
drunkenmaster
Apr 7, 2010 12:04 PM
imzjustplayin
24
Jan 28, 2010 11:39 AM
mortificationrock
Jul 17, 2007 08:52 PM
CivicBoi
Nov 19, 2002 03:04 AM
citanest
Jan 14, 2002 10:26 PM
