Clicking/popping sound when slowing down and on bumpy roads
Ok so I've been trying to find info online with no luck about these sounds coming from the front end. It sounds like a clicking/popping sound when going over bumps or even a slightly bumpy road and also when I'm slowing down. I was thinking it was the ball joint but I looked at them and the boots are fine no crack that I can see and no grease anywhere. I shook the cv joints with my hand lightly and there's a lot of play in them and when I did this I heard what I think is the same sound, but at the same time when I'm accelerating and turning there's no sound only when I slow down and driving a bumpy road. So I'm not really sure what's going on, so any help with this is appreciated. I have a 93 4 door.
I have a 93 civic dx. I recently replaced (about a month ago) the inner and outer tie rods on the passenger side and both front rotors. I checked the pads and they're pretty beat but still have a lil life left in them. Also my driver side CV is pretty shitty and my neighbor said that could be making the sound... Its really easy to move up and down with my hands.
A bad axle can make clicking/popping noises. That is typically while turning.
If the springs are using a progressive spring rate (coils extremely close to each other) you might be getting noise from them making contact with each other, although a noise like that is not common on the older cars. you can put a thin piece of rubber between the coils to see if it goes away. You should also make sure that the thin rubber isolator is on top of the spring still. Any rubber that is in contact with the spring is for noise reduction.
MatteBLK
Jan 19, 2015 11:34 AM
ksettles619
Apr 27, 2012 11:49 PM
joelmatt89
Jun 14, 2011 07:54 AM
