96 civic with b18a/b swap - EGR block off vs EGR delete
Old Sep 23, 2015 | 08:49 PM
Faker's Avatar
Default 96 civic with b18a/b swap - EGR block off vs EGR delete
i've seen some threads on how to do the block off but does anyone do an EGR delete very often? and if not why not? 96 civic with b18a/b swap
Old Sep 23, 2015 | 09:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default re: 96 civic with b18a/b swap - EGR block off vs EGR delete
Isn't "block off" and "delete" the same thing ??? Remember that if your ECU doesn't have an EGR circuit in it, it will not function just because the lift sensor and/or solenoid is attached to the intake manifold. You can remove them and use a "block off" plate to close the exhaust gas passageway from the head to the intake manifold.
Old Sep 23, 2015 | 11:18 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Why are you using an automatic pr4 obd0 intake manifold?
You should be using an obd2 p75 intake manifold.
Old Sep 24, 2015 | 12:32 AM
oneheadlight's Avatar
the HX is the only engine I know of in the 96-2000 range that has an EGR port..
Old Sep 24, 2015 | 01:54 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
It says they have a b18a/b swap.
But yes only the hx civics have an egr in that range. Also preludes, but those are ruled out via the swap and chassis.
Old Sep 24, 2015 | 06:48 AM
tony_2018's Avatar
Fish Twig
Than it is wrong about its research
Old Sep 30, 2015 | 07:06 PM
Faker's Avatar
what is a p75 obd2 manifold from? i'm not that familiar with codes, i got the engine like this and dropped it in... This is my first time figuring this sort of stuff out. it is a B18a block and intake manifold as far as i can tell. It does have an EGR right? Also what can you use to block off any excess ports?
Old Sep 30, 2015 | 07:07 PM
tony_2018's Avatar
Fish Twig
Do you not know what an egr looks like? After all your searching you did you haven't seen one yet?
Old Sep 30, 2015 | 07:09 PM
Faker's Avatar
yes i know what it looks like. I thought the b18a had an egr originally in the integra but i got confused from previous comments
Old Sep 30, 2015 | 07:12 PM
tony_2018's Avatar
Fish Twig
Don't you have the engine within your vicinity?
Old Sep 30, 2015 | 07:14 PM
Faker's Avatar
yes i do.
Old Sep 30, 2015 | 07:19 PM
tony_2018's Avatar
Fish Twig
than it would've been easier to confirm it yourself since the motor is in your car, don't you think?
Old Sep 30, 2015 | 07:21 PM
Faker's Avatar
yep i know the EK chasis has an egr but my engine is not a D series its an LS swap. I never pulled the engine myself so it is hard to confirm that when i don't have an integra sitting in front of me for comparison
Old Sep 30, 2015 | 07:30 PM
tony_2018's Avatar
Fish Twig
After reading this post, you just confirmed with me you don't know what an egr looks like. You can't even look at the engine in your civic to verify this. The engine is mounted no different when in an integra.
riddick5
May 3, 2014 04:13 PM
ef_si
Aug 10, 2013 12:55 PM
mynameizstitch
Feb 16, 2012 07:22 PM
p3terson17
Apr 2, 2007 02:32 PM
