Steering wheel two torx screws won keep stripping
Old Sep 23, 2015 | 05:38 PM
WaryDriver's Avatar
Default Steering wheel two torx screws won keep stripping
There are two torx screws I cannot remove from any 96-00 Civic steering wheel from junkyard. I've bought two sets of torx bits one set from Home Depot and another set from Autzone. Was using the T30 bit if I remember, whatever size was the biggest i could get in the head. First I had the bits on a thick rubber screwdriver. Pressing down full force on the head and turning CCW would not move and stripped eventually after many tries. Then brought my reversible electric driver and loaded the T30 bit. The same result I would not back the screw out and finally stripped head after head. I use torx bits all the time for removing torx screws. The usual thing about these screws is that the heads are prone to stripping because their heads dont have deep rigid holes but instead shallow holes that arent rigid but instead smooth edges inside.
Old Sep 23, 2015 | 05:42 PM
Former User's Avatar
Default Re: Steering wheel two torx screws won keep stripping
What the question?
Old Sep 23, 2015 | 05:46 PM
WaryDriver's Avatar
Originally Posted by RonJ
What the question?
How do I get these torx screws loose? I've not been able to do anything but strip them on 5-10 donor cars that have the steering wheel I want. Havent tried my car but it would be the same result.
Old Sep 23, 2015 | 05:49 PM
I've had no problem removing them from my Civics. Maybe spray them with some penetrating oil before attempting removal, or drill them out.
Old Sep 23, 2015 | 06:08 PM
eghatch9295's Avatar
Stancetard Hate Monger
use an actual torx screwdriver and channel locks. never had a problem.
Old Sep 23, 2015 | 09:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
How about using the proper sized torx bit socket, a proper length extension that fits the socket, and a long ratchet that fits the extension... this way you can slowly, in a controlled manner, apply the necessary pressure toward the torx fastener AND the counter-clockwise twist of the ratchet.
Old Sep 24, 2015 | 06:08 PM
tony_2018's Avatar
Fish Twig
definitely proper size torque bits.
Old Sep 24, 2015 | 06:37 PM
Bently_Coop's Avatar
Steve at Heart
Are these torx screws with the security nipple?
Old Sep 25, 2015 | 01:37 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
^ No, they're just regular Torx. And I have definitely been in OP's boat (province that salts its roads... = rusty everywhere). Never like 10 in a row, though. OP should ensure he is using the correct Torx driver, as well as pack these in his tool kit: Mastercraft Maximum Impact Bolt Remover Set, 13-pc | Canadian Tire
Old Sep 25, 2015 | 04:32 PM
Steve at Heart
Penetrating oil may help as well. Would be careful around electronics though.
With Tha Flow
Honda Civic (2001 - 2005)
Aug 24, 2018 06:35 AM
SoFresh1189
17
Feb 19, 2010 10:50 PM
Rikaro
Apr 17, 2008 09:20 AM
Turbo Powa
Jun 24, 2004 02:16 PM
