anyone using an oil cooler?
Old Nov 5, 2002 | 03:09 PM
Boostless97Lude
Guest
Posts: n/a
Default anyone using an oil cooler?
i know that on a B18C5, it's got a liquid oil cooler at the oil filter... well, the H22 has this too.....
i was wondering if anyone was using and aftermarket air oil cooler on their ITR. the reason i wonder, i was curious if the filter relocater would work on them the same as the do on a non liquid cooled oil setup (yeah, i realize that sounds confusing, but i think you get my point)
Old Nov 5, 2002 | 03:10 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: anyone using an oil cooler? (Boosted97Lude)
I know of at least two ITR's with aftermarket oil coolers. Search here and in the road racing/autocross forum.
[edit] Linky --> https://honda-tech.com/zerothread?id=151683 [/edit]
Search is the fizzle!
[Modified by Splat, 7:12 PM 11/5/2002]
Old Nov 5, 2002 | 03:26 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone using an oil cooler? (Splat)
DAMN!!!!!!
that is freakin expensive
Old Nov 5, 2002 | 03:38 PM
pinota's Avatar
Here´s pics of my setup.
9 row Racimex/Mocal oil cooler and Mocal sandwich with thermostat.
All the setup coast me $275
Old Nov 5, 2002 | 03:44 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone using an oil cooler? (pinota)
what size lines are those?
and all you used was the sandwiche plate? where you able to retain your liquid oil cooler?
Old Nov 5, 2002 | 03:51 PM
Tommy_Gunns's Avatar
When changing oil, is there a way to drain the oil cooler?
Old Nov 5, 2002 | 03:56 PM
pinota's Avatar
The stock ITR oil cooler sandwich stay there. You just have to remove the oil filter, then put the Mocal sandwich on the stock oil filter bolt. The Mocal sandwich bring a new 20mm 1/2 bolt to attach on the stock ITR oil cooler sandwich. You couldn´t put the lines on the Mocal sandwich if you whould attach it on the block, because of the oil pressure switch. You need some lift to on the block to put the lines.
The Mocal sandwich is , mine came with the thermostat included.
That´s the main problem when using a oil cooler, how to remove the 0.5 litter inside the cooler, i have to find out that too.
[Modified by pinota, 12:57 AM 11/6/2002]
Old Nov 5, 2002 | 04:01 PM
reefer_bob's Avatar
Turn the car upside down...
Old Nov 5, 2002 | 04:24 PM
Eric R's Avatar
Default Re: anyone using an oil cooler? (reefer_bob)
...how about compressed air?
Old Nov 5, 2002 | 04:25 PM
Splat's Avatar
Default Re: anyone using an oil cooler? (Tommy_Gunns)
Read N24RE's full post. He discusses a way.
Old Nov 5, 2002 | 04:42 PM
You mean this?
https://honda-tech.com/zerothread?id=168859
Old Nov 6, 2002 | 02:24 PM
pinota's Avatar
Ok, here´s pics of the Mocal sandwich with thermostat.
They´re a bit yellow.
Old Oct 13, 2004 | 10:50 AM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinota &raquo;</TD></TR><TR><TD CLASS="quote">Here´s pics of my setup.
Reviving an old thread..... Anyone know where I can get a Mocal sandwich like that?
Old Oct 13, 2004 | 11:28 AM
Rene M's Avatar
Default Re: anyone using an oil cooler? (Pompiuses)
Beware watch those stainless lines they well saw through every thing in that bay...
I would recomend you sleeve them or clamp them down every couple of in...
Old Oct 14, 2004 | 12:05 AM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know where I can get a Mocal sandwich like that?</TD></TR></TABLE>
Old Oct 14, 2004 | 01:16 AM
slammed_93_hatch's Avatar
http://www.racerpartswholesale.com/filtmt.htm
i just wen to http://www.goog.com type in mocal oil filter sandwich and what do you know 3 down and there it is
Old Oct 14, 2004 | 01:27 AM
Pompiuses's Avatar
Default Re: anyone using an oil cooler? (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">http://www.racerpartswholesale.com/filtmt.htm
i just wen to http://www.goog.com type in mocal oil filter sandwich and what do you know 3 down and there it is</TD></TR></TABLE>
http://www.racerpartswholesale.com/mocal.htm
It's the sandwich Adapter with 20mm thread size (Part No. SP1FT) I'll need, right?
Old Oct 14, 2004 | 02:01 AM
Pondus's Avatar
Yes that's the one.
Old Oct 14, 2004 | 03:41 AM
Pompiuses's Avatar
Default Re: anyone using an oil cooler? (Pondus)
Will the stock oil filter fit on top of the Mocal sandwich, or will it be necessary with an external mount.
Old Oct 14, 2004 | 05:31 AM
Dr Pooface's Avatar
I used a lot of permacool parts with my setup: http://permacool.com/
Old Oct 14, 2004 | 05:13 PM
Street Ghost's Avatar
Default Re: anyone using an oil cooler? (Dr Pooface)
What size lines are you guys running? -8AN? -10AN?
Old Oct 14, 2004 | 05:46 PM
IN VTEC's Avatar
With the M20x1.5mm adapter, you can reuse your stock filter.
I also got my Mocal thermostat'd sandwich adapter from RPW. They're right up the way from me. If you have a Goodridge vendor/dealer over in Europe, it might be easier to get one from them. The part number is: SBTB-12 (comes with (2) 1/2" NPT to 1/2" BSPP adapters). You'll also need a separate M20x1.5 adapter (EB-M20) since the SBTB-12 comes with the 3/4"x16tpi adapter.
There's also a "Blanking Plate" (BP-01) and "Sealing Ring" (SR-5) listed that might be the individual parts instead of wasting money on the included 3/4"x16 adapter and 1/2" BSPP adapters that you won't need anyways.
Personally, I'm tempted to use a 3/4"x16tpi adapter in place of the M20x1.5 I have now so I can use a larger filter from like a Ford truck or whatnot.
I use -10AN lines, but I haven't had the chance to measure the pressure drop.
I suggest using Goodridge PHS-10DB hose separators and Adel clamps (15/16" or 1") to secure the braided line out of the way of things.
Pictures of mine: I use a Setrab 125 cooler mounted sideways instead of 'fittings up'. I'd just as soon undo the lower hose-end to drain the oil than mess with stabbing and blowing stuff up.
http://portfolio.iu.edu/bchang...1.jpg
http://portfolio.iu.edu/bchang...2.jpg
http://portfolio.iu.edu/bchang...3.jpg
http://portfolio.iu.edu/bchang...4.jpg
http://portfolio.iu.edu/bchang...5.jpg
http://portfolio.iu.edu/bchang...6.jpg
http://portfolio.iu.edu/bchang...7.jpg
http://portfolio.iu.edu/bchang...8.jpg
http://portfolio.iu.edu/bchang...9.jpg
http://portfolio.iu.edu/bchang...0.jpg
Old Oct 14, 2004 | 06:16 PM
Dr Pooface's Avatar
Default Re: anyone using an oil cooler? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
I use -10AN lines, but I haven't had the chance to measure the pressure drop.</TD></TR></TABLE>
I have about 12' of -10 line, lost about 4 lbs at wot and nothing at idle.
Old Oct 14, 2004 | 07:39 PM
BDBGoalie1982's Avatar
Im running a B18C/B16A block head combo in a GSR, so no factory oil cooler for me
I used a B&M oil cooler ($109.99 from jegs).
However the POS didn't come with the right filter plate adapter so i had to buy a universal one to go on the back of the block(~$15).
The kit also comes with 1/2" oil cooler hose, which i replaced with 1/2" steel braided hose (a #8 from jegs i belive ~$69.00 for 15 ft)
However i used hose clamps and have no leaks, still haven't hooked up a oil press and oil temp to check details though.
Works really nice, oil changes are a breeze, except the first time. Had to go to NAPA and match the filter since no real numbers were on the B&M filter
I'll see if i can get pics up soon
Old Oct 14, 2004 | 11:17 PM
Default Re: anyone using an oil cooler? (BDBGoalie1982)
Would there be any problems running -8AN SS lines? Also, about how much are the Setrab coolers?
