d15b7 misfiring
Old Sep 20, 2015 | 05:39 PM
Josh C's Avatar
Default vtec dizzy on nonvhead ?
swapped a d15b7 in my ek hatch. Running a p06 with a conversion harness. Runs but is misfiring bad especially in the lower RPMs.
When I did the swap I used my obd2 dizzy off my y8 head becuz of the connector issue. (motor was blown) Would this cause the misfire? do i need different spark plugs with the different dizzy? i chcked for vacuum leaks, none i have a cel so ill pull the codes and post later.thanks
i have the d15 dizzy so i might just splice it in but i wana be sure it will fix it before hacking up my harness
Old Sep 21, 2015 | 05:12 PM
Josh C's Avatar
Default Re: d15b7 misfiring
bump pls jhelp. should i try usin the d15 dizzy? i was told the y8 wuold work fine.
Old Sep 21, 2015 | 05:18 PM
NotARaCist's Avatar
I never narc'd on nobody!
<p>https://honda-tech.com/honda-civic-d...sting-3002401/</p><p>Pulling and posting those CEL codes are a requirement, not a recommendation. &nbsp;Do it. &nbsp;While you're doing that, do a compression test, and tell us what color your spark is on all four plugs. &nbsp;Did you hear the donor motor running before installing it in your car, or are you just going off someone else telling you that it was good?</p>
Old Sep 21, 2015 | 05:30 PM
White_EG1's Avatar
Yes, see if a d15b7 dizzy will work.
Old Sep 21, 2015 | 06:31 PM
Josh C's Avatar
the motor was in a eg sedan heard it run mint. So yea ill check the d15 dizzy
Old Sep 22, 2015 | 01:31 PM
Josh C's Avatar
bump
Old Sep 22, 2015 | 01:44 PM
NotARaCist's Avatar
<p>
Originally Posted by NotARaCist
</p><p>https://honda-tech.com/honda-civic-d...sting-3002401/</p><p>Pulling and posting those CEL codes are a requirement, not a recommendation. &nbsp;Do it. &nbsp;While you're doing that, do a compression test, and tell us what color your spark is on all four plugs. &nbsp;Did you hear the donor motor running before installing it in your car, or are you just going off someone else <em>telling you</em> that it was good?</p><p>
</p><p>If you won't do diagnostic tests, we aren't going to help you. &nbsp;You were given a very short list of things to do. &nbsp;Do them.</p>
Old Sep 23, 2015 | 03:38 PM
ShaneDur's Avatar
Cause of my d16y8 misfiring had no idea why it was had mechanic take it apart for headgasket and found the exhaust valve has a chunk out of it
slob20ef
May 18, 2009 06:14 AM
todubbled1
Jan 31, 2009 07:18 PM
87shytwhip
May 6, 2008 08:45 PM
bleebdat
Jan 10, 2004 09:30 AM
