Suspension question EG3
Old Sep 20, 2015 | 03:39 PM
Civi_eg3's Avatar
Default Suspension question EG3
Finally have found myself a clean EG3 and its bone stock fist thing i want to star with is suspension but not to sure whatto go with. Goal for the car to be able to drive decently comfortable but still take it to the track and corner. and help with suggested coil overs and spring rates welcome thanks!
Old Sep 20, 2015 | 04:17 PM
White_EG1's Avatar
Default Re: Suspension question EG3
Koni yellow strut with ground control sleeves. The rates are perfect.
Old Sep 20, 2015 | 05:03 PM
Civi_eg3's Avatar
Ok cool thanks are these adjustable? and what size of rims and tires will i be able to fit with no rub? going for as wide as possible within reason... going to need that traction.
Old Sep 20, 2015 | 05:15 PM
NotARaCist's Avatar
I never narc'd on nobody!
<p>The FAQ sticky is not optional reading, and your blatant failure to read it is, quite frankly, insulting to the men and women who have worked to put it together and keep it current.</p><p>https://honda-tech.com/honda-civic-d...tions-1998336/</p><p>Read it before posting. &nbsp;Your question is directly answered, by an extremely knowledgeable member.</p>
Old Sep 20, 2015 | 06:36 PM
White_EG1's Avatar
No, but if you want adjustability and all of that look for a set of tein coilovers, those ride nice!
Do you mean you wanna do that stance ****? Please don't, that actually helps you lose traction. But IMO for the rims and tires a 15x7 with a 205/45/15 and 2.5" drop won't rub, it will handle well and give you all the traction you'll need.
Old Sep 20, 2015 | 06:55 PM
Civi_eg3's Avatar
hahahaha hell no none of that stance BS. is 15x7.5 pushing it for width? and are camber arms needed?
Old Sep 20, 2015 | 07:28 PM
eghatch9295's Avatar
Stancetard Hate Monger
yes that is pushing it. big time overkill for a d/d.
Old Sep 20, 2015 | 07:37 PM
Civi_eg3's Avatar
all right ill stick with the 15x7.. thinking on going with the progress cs ll coilovers. Camber kits needed?
Old Sep 20, 2015 | 07:39 PM
depends on your drop.
Old Sep 20, 2015 | 07:43 PM
Civi_eg3's Avatar
well going to be getting adjustable. but i dont want it on the ground just to tuck the wheels in nice. will i need an offset for 15x7 with 205/45/15
Old Sep 20, 2015 | 07:51 PM
NotARaCist's Avatar
<p>Yes, you'll need stock, or near stock offset.</p>
Old Sep 20, 2015 | 07:55 PM
or roll your fenders with a bat like every other douche
Old Sep 20, 2015 | 08:02 PM
Civi_eg3's Avatar
ok just checking and no im not going to roll my fenders with a bat. cars to clean to not do **** the correct way. which is why im asking questions here.
Old Sep 20, 2015 | 08:09 PM
NotARaCist's Avatar
<p>Also, you won't need camber arms. &nbsp;Camber doesn't kill tires, toe does. &nbsp;You also don't need an adjustable suspension. &nbsp;Just get a solid setup that works. &nbsp;Hint: Koni/GC.</p>
Old Sep 20, 2015 | 08:13 PM
Civi_eg3's Avatar
So Koni yellow? and GC springs? also side question. any recommended rim brand?
Old Sep 20, 2015 | 08:19 PM
White_EG1's Avatar
Honestly OP, it seems you want adjustable coilovers and I would probably tell you to go that route. I can't imagine being stuck at a specific height.
Just get some 15x7 rota slips, tein basis coilovers, and like I said 2.5 drop and you wont have any problems, no fender rolling, no nothing.
Old Sep 20, 2015 | 08:26 PM
Civi_eg3's Avatar
if i go adjustable ill go with the progress cs. amd i like the look of the rota grid better just worried about offset.
Old Sep 20, 2015 | 08:34 PM
White_EG1's Avatar
You'll be fine if you keep the height at 2" anything lower and you'll start running into rub
Old Sep 20, 2015 | 08:35 PM
Civi_eg3's Avatar
cool thanks for the help
coupenzhatch
Suspension & Brakes
Mar 26, 2010 12:31 AM
A Blue Lude
15
Jul 8, 2009 12:23 AM
beefjerky
Oct 10, 2005 09:30 PM
JohnnyM
Jun 16, 2002 12:08 PM
