B20B, B20Z piston rings are the same?
Old Sep 17, 2015 | 07:30 PM
kebroz's Avatar
Default B20B, B20Z piston rings are the same?
I am going to rebore my B20Z + .25mm, but as I run turbo I would like B20B pistons .
Rings + .25 for B20B 13021-P3F-003 are not available anymore, I would like to know if those for B20Z 13021-PHK-003 are exactly the same, if the only difference it is the part number?
Thank you very much..
Laurent
Old Sep 17, 2015 | 10:18 PM
TheShodan's Avatar
Moderator
Default Re: B20B, B20Z piston rings are the same?
compression in b20Z is higher
Old Sep 17, 2015 | 10:52 PM
kebroz's Avatar
B20Z rings on B20B pistons it's ok?
That is the is the question.. :-)
Old Sep 18, 2015 | 06:09 AM
spAdam's Avatar
Loved
Community Favorite
I would check the helm manual, there should be specs for inspecting the rings. That should give you an idea if they are the interchangeable or not.
Dammit, I have a set of .25os PHK pistons and rings back in Florida. I have no idea which box I put them in though.
Old Sep 18, 2015 | 10:22 AM
TheShodan's Avatar
Moderator
Ok. I'll recirculate the argument. The ONLY difference between the two is the compression ratio and dome height. As a manufacturer of millions of units, it is a matter of logic that you use the same set of rings for the engine unless it is specialty. So, it means YES, they use the same stuff. A helms will confirm it, but as a matter of production schedule and vendor use, YES.. Yes.. and did I mention, YES?
JJDub
Engine Machining & Assembly
May 31, 2017 07:30 AM
kebroz
Honda CR-V & Element
Sep 18, 2015 07:22 AM
hondachris1994
Dec 29, 2008 07:59 AM
siis2fast
Jun 7, 2005 03:52 AM
b20ek
Jun 6, 2003 06:14 AM
