Suspension & Brakes Theory, alignment, spring rates....
Newbie need brakes help
Old Sep 14, 2015 | 08:35 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Newbie need brakes help
I'm about to bleed my first brake job. Let's not debate how to do it as there are many ways.
My question is, why is the bleeder valve pointing up? If I was to use the gravity method, how is it suppose to drain/drip out?
2014 Odyssey rear.
Old Sep 15, 2015 | 06:15 PM
Bently_Coop's Avatar
Steve at Heart
Default Re: Newbie need brakes help
Bleeder valve is on top so the air will release from the caliper. Gravity method requires a hose leading to a container or back to the master cylinder.
Old Sep 15, 2015 | 08:12 PM
GoLowDrew's Avatar
Old Member
25 Year Member
So where the arrow is at is NOT where I connect the hose to, to let the fluid drain out?
Old Sep 15, 2015 | 08:36 PM
Tyson's Avatar
yes that is the bleeder screw. (take the rubber cap off)
air in the caliper is at the top. so its at the right spot.
the master cylinder is far above the caliper and because its higher it will push fluid and air through, even if at some point it goes upward... its all still below the master cylinder.
dleccord
Suspension & Brakes
12
Feb 20, 2013 09:52 PM
type Gendy
Suspension & Brakes
Apr 26, 2009 11:11 AM
candy eg
Dec 27, 2005 07:32 PM
92integraVTECgsr
Nov 4, 2005 05:39 PM
SIMATIC
May 2, 2003 08:46 PM
