V6 accord power steering/idle rpm issue
How's it going? I have a 2003 v6 6speed accord. Issue is at idle the power steering hardly works or at times doesn't work at all, but If you raise the Rpms the slightest bit "100 Rpms" power steering works perfect. Driving the car no issue that I notice.
Changed the pump
Changed the pressure switch
From what I understand is that the car does not have a IACV because it's drive by wire, is there something else that bumps up the idle when the power steering calls for it? Also turning on the ac at idle does not increase the idle rpm
Thanks
John
Changed the pump
Thanks
John
93egboosted
Sep 19, 2015 03:03 AM
Fuzzychaos
Honda Civic (2001 - 2005)
Jun 21, 2015 11:50 AM
kingofbytes
19
May 13, 2012 03:49 PM
First Honda 1976
May 1, 2004 04:11 PM
