B16 oil light flickering issue
Old Sep 10, 2015 | 05:29 AM
hatch4lifeSi's Avatar
Default B16 oil light flickering issue
My b16 oil light was flickering so i changed the oil pump. I turned the car on after replacing it. It ran fine for about 15 min then it started idling rough and the oil light started flickering again. did any body else have the same issue and how do you get rid of this issue
Old Sep 10, 2015 | 06:07 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: B16 oil light flickering issue
is the oil pickup clogged? are you able to verify oil is getting to the head?
clogged oil filter? get an gauge and find your pressure, what is it at?
Old Sep 10, 2015 | 06:18 AM
thank you i will try those steps next
Old Sep 10, 2015 | 06:23 AM
delsolintegra's Avatar
I once had a leak at the oil pressure sending switch above the oil filter on a D16z6. After replacing the sending switch with 2 different non OEM switches I got a flickering oil light. I replaced the switch with a OEM one and the light quit flickering. I think the diaphragms in those switches are critical.
Old Sep 11, 2015 | 03:39 AM
thank you, i will look into it
Jeremy087
Honda Civic (2001 - 2005)
Apr 6, 2016 06:45 AM
Andre Dixon
Feb 17, 2016 06:50 PM
Schultzie
Jul 10, 2010 08:58 PM
badboy409
Jul 2, 2005 10:24 AM
grippgoat
Mar 14, 2002 05:13 PM
