Skunk2 Pro2/3
At the moment I have a B18C with Skunk2 Tuner 2's (slight head skim to raise compression) Skunk2 valve springs/retainers, TWM itb's, standalone ecu. Spoon 4-2-1 2.5" header making 220bhp at the fly.
I was thinking of Wiseco 12.5:1 pistons, ARP rod bolts, ported GSR head, better header and Skunk2 Pro 2's unless you can suggest otherwise? Didn't really want to sleeve the block if possible.
I assume you're running the GSR crank and not an 89mm crank?
I personally think pro 2's will be a little big, but still work ok if you get a better header to go with the ported head. I'm not a fan of ITB's on B series myself, and don't have any personal experience, but I think a S2 Ultra street intake manifold would go a long ways on this motor and kill those ITB's
Try pro2 they'll suit this build better. Pro 3(270 at .050) is a bit much for a 1.8 engine. A guy here slowsleeper used pro2 on a 82mm and made 240 or so.
I just put pro2s in my 1.8 last weak and they feel great. My setup is
81.5 gsr bottom 13.3:1
B16 head
Performer x
Skunk2 alpha Tri y
70tb
3inche cai
3inche exhaust
Just switched from spec4s and it feels a lot better
B16 head
Performer x
Skunk2 alpha Tri y
70tb
3inche cai
3inche exhaust
LOL. Just because you have positive dome doesn't make it 13.3:1. I have positive dome and I'm around 12.5:1.
PR3 on an LS crank/rods will be low 12's unless the head/block has been machined a ton.
I don't think this setup ever existed...convenient it "let go"
Not to keep arguing but the main line had to have 15thou taken out and then I had the deck done when we were all finished the Pistons came out of the hole 2.5 thou. Using a compression calculator it came out to 13.3. But it doesn't mater now it done and know I'm switching to b20
Just try pro 2 and degree em! Pro 1 will beat tuner 2 up to a certain point in the rpm range. But it generally depends on the setup. Pro series are a hard profile to beat without compromising.
Btw. Are you the dude on YouTube with the stock b18c block with itbs and skunk2 cams?
