Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Help! Replaced Alternator, Car won't start.
Old Sep 7, 2015 | 04:01 PM
kaivorth's Avatar
Default Help! Replaced Alternator, Car won't start.
Long story short, was driving on the highway, my speedometer stopped working. Then the red battery symbol came on. Later that day, all my sensors stopped working (Fuel, RPM meter, radio, lights went dim) Finally my car just died. Red Battery light came on (Charging system)
Figured it was the alternator, had a lot of low voltage o2 sensor codes and whatnot.
Car now starts, still has charging symbol.
UPDATE
I feel like an idiot. The Negative Terminal on my battery wasn't tight of all things. Tightened it down, started her up, and my charge light was still on. I had blown the alternator fuse from not having my negative terminal connected when I first tried to start it. Diagnosed with the help of a mechanic at this point ugh. Replaced the fuse and all is good.
Old Sep 7, 2015 | 05:45 PM
toyomatt84's Avatar
Sanji
Default Re: Help! Replaced Alternator, Car won't start.
How about your engine grounds? Also, it seems more like a Multiplexer issue with the gauges malfunctioning.
Old Sep 7, 2015 | 06:48 PM
kaivorth's Avatar
Funny you mention that. Went back out there, my ground on the negative was loose. Tightened that up, car starts, but I still have that charging light on? Did I get a bad re-manufactured one...?
Time to get a multi-meter or bring it to the shop, ugh.
Old Sep 7, 2015 | 07:19 PM
toyomatt84's Avatar
Sanji
Try cleaning your battery terminals?
Old Sep 7, 2015 | 07:24 PM
kaivorth's Avatar
No crud on the negative, new terminal and wiring. I might try cleaning the positive though.
Old Sep 9, 2015 | 09:39 AM
jhbknyc's Avatar
Try to inspect the connector that goes on the alternator for wire damage and for the connecto it self.
Old Sep 11, 2015 | 02:56 PM
prodjay10's Avatar
Have you had the battery checked out? May be why your alternator cramped out. Its happened to me.
I had the alt fixed, then the battery stopped working, replaced it and it still wouldn't charge. The battery took out the alt again. Turns out the battery was bad from the beginning. Had to replace alternator. Now it works great.
Old Sep 13, 2015 | 09:17 AM
kaivorth's Avatar
sunshine5882
Jan 18, 2013 01:15 PM
BlueIntegraBoy
Jan 18, 2007 01:53 AM
GMon3y
Nov 29, 2006 11:27 AM
ownedbyvtec
Aug 20, 2003 10:45 AM
shadowdawn
Aug 9, 2003 06:23 PM
