Help with B18C build - silicone hose kits?
Old Sep 2, 2015 | 09:18 PM
Mugenkid's Avatar
Default Help with B18C build - silicone hose kits?
I have a 93 civic si.. I'm currently working on a B18c1.
I'm looking for silicone tubing for all the rubber tubing for my car and for this swap.. any good quality kits out there?
Old Sep 2, 2015 | 09:29 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default re: Help with B18C build - silicone hose kits?
<p>We are not your personal shoppers.</p>
Old Sep 2, 2015 | 09:31 PM
tony_2018's Avatar
Fish Twig
get the cheap ebay kits, its all the rave!!!! super rare ultra mad wannabe jdm yo
Old Sep 3, 2015 | 05:10 AM
GrantMC2's Avatar
Old Sep 4, 2015 | 08:28 PM
Mugenkid's Avatar
I understand that.. but that's not what I asked.
Old Sep 6, 2015 | 08:44 PM
purgat0ry's Avatar
Then you should totally understand why you should look for your own damned kits.
Old Sep 7, 2015 | 08:28 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Help with B18C build
I think that is understood, but how does one differentiate quality from non quality.
What makes one manufacturer better than another on silicone hosing?
What does someone look for to know if the hoses are quality or ****?
Or..... Are all silicone hoses equal?
Or is there no way to visually tell quality and so you just have to do the trial and error?
Old Sep 7, 2015 | 03:18 PM
oneheadlight's Avatar
Default Re: Help with B18C build - silicone hose kits?
I've heard to stay away from any silicone hoses since they tend to leak over time. I was reading a research paper (I'll have to dig for it, find it again) that some materials science engineering students wanted to see what the material did over time. They found that over time it weeped coolant. I'm not sure if it's because the coolant interacts with the silicone, but that's my thought. Might be safer just to get the regular epdm rubber hoses and not have to worry if it will leak. Cheaper too!
Old Sep 7, 2015 | 05:53 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
It's pretty well known the silicone is water permeable.
It's why the con to silicone is that you will be consistently topping up your coolant. The pro is it will handle almost twice the temperature.
So essentially, for most builds the OEM EPDM rubber hoses are superior. However in some turbo builds where the temps are much higher than normal, the silicone is beneficial but require much more upkeep in general.
The other con to the silicone is the bands cut into the hoses pretty easily and so it can be much more challenging to tighten and secure the slick hoses to connections without damage or slippage.
Old Sep 7, 2015 | 11:25 PM
NotARaCist's Avatar
<p>You are grossly exaggerating the permeability of the hoses. &nbsp;Yes, they are more permeable, but you don't have to &quot;constantly&quot; fill your coolant. &nbsp;The most common leak is caused by people using OEM clamps, which are not good enough for silicone hoses.</p>
Old Sep 8, 2015 | 10:03 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I hear what you are saying. Consistently may be a better choice of words.
What I meant by constantly is it will be a permanent, on going thing, to top up the coolant. It won't be a fill it and forget about it application.
I did not mean as a daily top up thing or a massive top up thing. Just that you will have to make a routine of constantly/consistently checking the coolant resevoir and then topping up as needed and that it will be needed from time to time.
EPDM on the other hand is not water permeable so once you have all leaks fixed up, you should not have to top up the coolant. If coolant is going down, there is a leak somewhere.
Hopefully that makes more sense is and a bit clearer for everyone.
Old Sep 8, 2015 | 10:13 AM
24TEN's Avatar
PHANTOM MENACE
Good info all around. If my car that has them were still running I'd go check LOL
Old Sep 8, 2015 | 10:34 AM
tony_2018's Avatar
Fish Twig
What clamps are suggested if one were to buy "da best" silicone hoses? All clamps I've seen are made of metal, even the autozone stuff.
Old Sep 8, 2015 | 11:53 AM
NotARaCist's Avatar
<p>
Originally Posted by tony_2018
What clamps are suggested if one were to buy &quot;da best&quot; silicone hoses? All clamps I've seen are made of metal, even the autozone stuff.
</p><p>Simple T clamps.</p><p>TomCat, I get what you're saying, but that's car ownership 101. &nbsp;Unfortunately, people don't do the super simple stuff like checking fluid levels when you stop at the gas station.</p>
Old Sep 8, 2015 | 01:28 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
<p></p><p>Simple T clamps.</p><p>TomCat, I get what you're saying, but that's car ownership 101. &nbsp;Unfortunately, people don't do the super simple stuff like checking fluid levels when you stop at the gas station.</p>
Yeah so true.
You can also reduce the amount you have to monitor by doing proper upkeep and also part selection based on application. Another thing most people skip out on, the upkeep/maintenance.
Old Sep 8, 2015 | 08:01 PM
tony_2018's Avatar
Fish Twig
Originally Posted by TomCat39
Yeah so true.
For some reason my little sister expects the car to tell her these things, low oil, low coolant, needs a timing belt job, needs new bushings, etc..etc...
Old Sep 9, 2015 | 10:34 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
LoL, yeah.... It's where I've been lazy but planning a Diary is the method I think is most useful beyond the typical regular fluid checks.
I currently have to check my oil every gas fill up, but that will be reduced to every few fills once I rebuild my engine and break it in properly.
Coolant can be a monthly or even possibly a quarterly check if you use EPDM hoses and have zero leaks. Even with my Heater Core leak, I typically only have to top it up once a month or so.
With silicone hoses, even with zero leaks, I would suspect it would need a monthly top up. Not a lot of fluid but some to keep it filled properly.
Keeping oil seals refreshed and non leaking helps from having to check your oil as often etc.
It's funny how people will drive their cars to the ground without ever checking anything. Then wonder why they spun a bearing when the oil is too low to service anything.
Old Sep 9, 2015 | 10:06 PM
Mugenkid's Avatar
Everyone has different experiences with products so that's why I asked.. so if you're going to be an *** then no need to comment..
Old Sep 9, 2015 | 10:10 PM
Mugenkid's Avatar
And this is the type of info I look for. Experiences with them and if they are worth a damn.. thank you to all that weren't on here just talk ****. But actually be helpful.. which is what a forum is about...
Old Sep 9, 2015 | 10:36 PM
tony_2018's Avatar
Fish Twig
What other well known brand company makes silicon hoses?
Old Sep 10, 2015 | 07:21 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
There was no need to return and stir the pot into a pissing match. What was said was said and you could have focused on the positive comments and ignored the negatives.
Instead you homed in on the negatives only just asking for a troll fight pissing match.
Thread closed before the fight begins.
Freemananana
Jun 20, 2014 02:57 AM
redline5th
Dec 21, 2009 08:35 PM
princess24
Apr 17, 2006 09:05 PM
CivicHB93JDM
Apr 19, 2005 09:44 AM
