Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2009 TL Battery Drain
Old Sep 2, 2015 | 09:07 AM
Satforn's Avatar
Default 2009 TL Battery Drain
I have some sort of parasitic battery drain (~ 1 AMP). I went through and pulled fuse by fuse to find which circuit is the issue. I found when i pulled fuse #15- 10 AMP Backup in the under the hood fuse box the draw went from 1 AMP to about 45 mAmps. My question is...what does this fuse serve? It's only description is "Back up"...not very helpful. I have no computer codes (had a friend run the scanner). Thanks!
Old Sep 8, 2015 | 05:55 PM
Vermont05452's Avatar
Default Re: 2009 TL Battery Drain
I too would like to know how this turns out?
Old Nov 21, 2018 | 03:27 PM
papa mike's Avatar
I am having same proble, unable to id fuse 15 which is a 10 amp fuse under the hood fuse box. causing 1 amp battery drain.
Voodooboy520
17
Dec 20, 2021 07:54 PM
monsterCHILD
Jan 6, 2011 04:28 PM
merch1
Mar 6, 2005 11:07 AM
Nameless RB26
Jan 8, 2003 05:35 PM
4doorH22
Audio / Security / Video
Sep 6, 2002 07:34 PM
