95 honda civic ex ac not working right
Old Sep 1, 2015 | 06:27 PM
Ramiro Valencia's Avatar
Default 95 honda civic ex ac not working right
I just replaced my ac compressor, reciever, expansion valve, my ac low pressure side is at 45 and high pressure side at 200 and i havent seen it go up
Any one know what it could be
Old Sep 7, 2015 | 10:41 PM
theAngryMarmot's Avatar
Default Re: 95 honda civic ex ac not working right
What exactly is it not doing right?
You pressures seem OK (assuming your ambient temps are in the 85-100 degree range and we are talking R134.)
Are you sure you added the proper amount of refrigerant? You didn't double charge the oil did you? Most new compressors ship pre-oiled and adding too much will hamper the system's capability.
Needles on the gauges fairly smooth, not jumping?
Old Sep 9, 2015 | 12:45 AM
slowcivic2k's Avatar
The low side pressure indicates transfer of heat (higher than freezing), the high side indicates heat transfer (near boiling, could be a bit higher). Stop replacing parts, and diagnose the problem you have. If you replace everything, you have no idea what the problem was, and it may occur again. Read this article, and take the time out of you day to provide information.
https://honda-tech.com/tech-misc-15/...oesnt-2900177/
pj08006
Aug 27, 2018 04:28 PM
Arts09
13
Apr 15, 2013 04:48 PM
tj051
Apr 13, 2012 07:18 AM
Muckman
Aug 15, 2010 07:03 PM
Edwardo911
Sep 3, 2004 04:53 PM
