2001 gsr cruise control
Old Sep 1, 2015 | 07:10 AM
98dxkoupe's Avatar
Default 2001 gsr cruise control
The green cruise control light on the dash is not lit up when i press the cruise control button where would i start to diagnose the problem?
Old Sep 1, 2015 | 10:57 AM
aw614's Avatar
10 Year Member
Loved
Default Re: 2001 gsr cruise control
is it working? I would start with the cruise control pedal bushing to check if it is still there or if it disintegrated. Then you should change the clutch pedal bushing switch and brake light switch as chances are those will probably be next to go.
Old Sep 1, 2015 | 12:11 PM
98dxkoupe's Avatar
No cruise control isn't working no green indicator on dash so cluth pedal bushing an brake pedal bushing?
Old Sep 2, 2015 | 04:42 AM
aw614's Avatar
10 Year Member
Loved
it most likely is the clutch pedal bushing, but I would suggest replacing all three pedal bushings. You can test it out by taping a penny to the area where the bushing is supposed to be. The clutch bushing to start the car is probably the worse one to do, the cruise control switch and brake light switch are easy to do.
01CRVLX
Honda CR-V & Element
Jul 1, 2014 09:29 AM
jimmydean06
Jan 1, 2014 01:23 AM
gripek
Honda S2000
Mar 18, 2009 11:58 AM
Sweetsystem
Aug 26, 2008 01:58 PM
Dezmon
Mar 9, 2007 06:38 AM
