95eg brake issues
Just bought a 95 eg and when at a stop the pedal will slowly sink to the floor and I have to back off an re press down. So I bleed the brakes and its still happens anywon had this issue I'm thinking I should replace the master cylinder any help is appreciated
<p>Master cylinder leak, brake booster failure, or check valve failure. Start by checking for leaks, both under the MC, as well as at the brake pedal assembly. From there, we can look into testing your brake booster.</p>
Just went an looked no visible liquid but the paint on the brake booster under an around master cylinder is either gone or wrinkled so maybe there's a small leak at the seal fluid level I can't say for sure but looks like it might have went down since I bleed the system yesterday ill mark it tomo to find out for sure if it is leaking should I replace the mc? Thanks for you help
If possible get one for a 91 EX SEDAN. It's a 15/16th and bolts right up to the 92-95 brake booster. No lines need to be re bent. Now is a great time to upgrade!
Your pedal will inspire a LOT more confidence.
AWD: Jeff
Suspension & Brakes
Jul 3, 2010 06:47 AM
Specail Ed
Mar 31, 2008 08:25 AM
