B20V css 85mm b17 crank turbo
Old Aug 30, 2015 | 02:02 PM
revsforglory's Avatar
Default B20V css 85mm b17 crank turbo
Head: b16
Crower stage 3 cams
Crower titanium valves & springs
Bwr top mount manifold
Arp head studs
Hot tanked
Port & Polish
Block: b20
85mm bore
B17 crank 81.4mm stroke
Cylinder support system
141.7mm custom rod
Custom piston (Dome)8.63cc (Comp height)28.67mm
It's my first time building a engine I like to know you guys thoughts on how long this could last or if it seems like a good set up any feed back would be lovely
Old Jan 9, 2017 | 04:18 AM
vtecmaster85's Avatar
Default Re: B20V css 85mm b17 crank turbo
how did this build go? big bore, short stroke, long rod b20 for boost sounds niice
Old Jan 9, 2017 | 08:38 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
That piston would be sitting awfully deep in the hole... unless the block has been milled a ton. I would have personally increased the compression height and reduced the dome volume to meet the same target compression as OP got with his specs. It should be a rev happy engine for sure... I like the idea.
I am interested to hear how it turned out as well... I hope all is OK.
GVL7
K Series
Dec 7, 2017 04:15 AM
Junaid K
Jun 6, 2014 10:23 PM
perronedb2
26
Nov 18, 2013 05:37 PM
DAYUIZ
Jan 14, 2003 12:21 AM
