Suspension & Brakes Theory, alignment, spring rates....
Brake Problem
Old Aug 30, 2015 | 01:04 PM
TeamTFR's Avatar
Default Brake Problem
I have a 1994 Del Sol and the brake pedal has alot of travel and is spongy. With the car turned off the pedal feels normal. So far I've replaced the following- master cylinder, booster, proportioning valve, and both rear calipers. Pads and rotors are good. Brakes have been bled properly and all fluid is new as well. I'm out of ideas
Old Aug 31, 2015 | 07:57 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Brake Problem
Caliper slide pins stuck maybe? You likely still have air in the lines. Bleed the fluid with the car turned on and use a 1 man bleeder. The pump and hold method is extremely inefficient.
The pedal gets firm after you turn the car off because the booster is not active after a few pushes.
Stance Movement
Jul 30, 2018 08:16 AM
tazz29
Jul 9, 2008 10:52 AM
burton_o6
Apr 21, 2008 09:04 AM
Neptronix
21
Mar 26, 2008 09:35 AM
GSR95T
Sep 4, 2002 09:21 AM
