Passenger side signal and passenger hazard do not work
I have a 2008 honda Odyssey ex. My passenger side turn signal does not work and the hazard lights on the passenger side are also affected. Momentarily I was able to play with the right turn signal lever by switching it up and down and magically it started working again. But now the problem has reoccured and i am able to use passenger turn signal and passenger side hazards do not work. Any ideas? I heard turn signal switch is problem on some fourm I also read some that said relay switch. Please help?
Is this the flash Relay on the 2008 Odyssey
Is the flash relay that gray box when I zoom in it says FR-3504
